Parking brake Help
Parking brake Help
I know there is lots of threads about this but I think I might be unique, I am trying to bring back an 06 A8L from the dead
it came to me with a park brake fault
sounded like they were working but I need to look anyway
hooked up my VCDS set it to open then turned the car off
needed new pads, ordered set, took the motors off and bench tested with 12volts both seem to work fine
tried to push piston back, way to much resistance, ordered new caliper seals (lots of corrosion)
put everything back together , hooked up VCDS closed caliper
tried to put in new thickness it seems like it takes but still giving me park brake fault and low pad
heres where mine problem becomes different when I try and set the park brake it says "Too steep"
I think maybe I have a yaw or longitudinal sensor out of wack
any thoughts?
any thoughts?
So I pulled out the battery and found the module on it side
so no wonder I was getting too steep
I also got the pad thickness to stay
but I still have an error/ light on dash
error 02440 maybe bad module or wiring
any thoughts?
any thoughts?
that is the warning on the instrument panel or the switch.
Do an output test and see what you get. You should see all the warning indicators blinking. You know like they should have been on a 737 Max 8
Fashizzkes84
15
08-14-2019 01:39 PM
iProDrive
11
03-12-2009 07:39 PM
Oo.et.oO
31
04-05-2005 10:06 AM
JasonS4+Festicle
12-20-2004 09:28 AM
