Partial VAG-COM options...
***Still working out the suspension details as it is very very tricky on the D3.
Audi A8 (4E/D3) Chassis VAG - COM Options and Codes.
The 2003 + (2004 + in North America) utilizes the latest Fiber Optic system (MOST) to incorporate multiple electronic functions throughout the vehicle. There for you will require a HEX - COM + CAN or HEX - USB + CAN cable
from Ross-Tec (www.ross-tec.com) to access the majority of components.
Please note - before making any numerical changes, copy and save the original coding before doing so.
By making any changes, you are doing so at your own risk.
Instrument Cluster - Control Module #17 (Instruments)
The following procedures will allow you to adjust various parameters associated with the instrument cluster.
Begin by selecting # 17 (Instruments) under the tab Common and then selecting #7 (Re-Code). The options for the cluster are in a 00xxxxx format.
Example: 0016401. This will remove all warning chimes for doors, trunk lid, fuel filler cap, and hood, but still provide an optical warning in the MFI. The warning chime and light for seat belt reminder will also be removed completely and the needles for the instrument cluster will be illuminated when the exterior lamps are off.
00??xxx: Extra-Options
+01 - Quattro (2nd fuel tank map)
+04 - Vehicle with clutch (no automatic transmission)
+08 - 2nd tire size (difference between summer and winter tires)
+16 - Tire Monitoring System (MY 2005 >
00xx?xx: Country-Setting
0 - Germany (km/h)
1 - Rest of World (RoW - left hand - km/h)
2 - USA (US - mph)
3 - Canada (CAN - km/h)
4 - Grea britain (GB - mph)
5 - Japan (JP - left hand - km/h)
6 - Arabian states (km/h)
7 - Australia (AUS - km/h)
8 - Rest of World (RoW - right hand - km/h)
9 - Japan (JP - right hand - km/h)
00xxx?x: Seat belt warning
Note: Options 3-6 are only avialiable for MY 2005 and above.
0 no seat belt warning
1 seat belt warning Europe-NCAP - Optical during warning, acoustical warning for 91 seconds activ.
2 seat belt warning USA and Canada old - Optical and acoustical warning for 6 seconds
3 seat belt warning USA and Canada NAR neu - Optical during warning, acoustical warning all 30 seconds
4 seat belt warning Europe-NCAP (incl. passenger) - Optical during warning, acoustical warning for 91 seconds activ.
5 seat belt warning USA and Canada old (incl. passenger) - Optical and acoustical warning for 6 seconds
6 seat belt warning USA and Canada NAR new (incl. passenger) - Optical during warning, acoustical warning all 30 seconds
00xxxx?: Illumination options
Note: Options 4-9 are only avialiable for MY 2005 and above. Options 0-4 with parking light LED off, options 5-9 with parking ligh LED on.
0 - Needles and Scales OFF
1 - Needles ON, Scales OFF
2 - Needles OFF, Scales ON
3 - Needles and Scales ON
4 - Needles and Scales ON
5 - Needles and Scales OFF
6 - Needles ON, Scales OFF
7 - Needles OFF, Scales ON
8 - Needles and Scales ON
9 - Needles and Scales ON
Comfort System - Control module #46 (Central Conv.)
Begin by selecting # 46 (Central Conv.) under the tab Common and then selecting #7 (Re-Code). We must first add +64 to the current falue to allow control with the key fob buttons.
+00001 - 10 Tamper alarms (GB, Ireland/PR-B09)
+00002 - USA logic and/or no DWA blocks (Thatcham deactivated)
+00004 - Selective central locking (PR-4K2/4K6/4K7)
+00008 - Anti-theft warning system (PR-7AH/7AL)
+00016 - Tilt sensor installed (PR-7AL)
+00032 - Control module for Trunk lid installed (PR-4E7/4E9)
+00064 - Comfort functions via remote
+00128 - Right hand steering (PR-L0R)
+00512 - Electric Rear blind installed (PR-3Y2/3Y5/3Y8)
+01024 - Confirmation anti-theft warning system via horn (PR-A8U)
+02048 - SAE rear lights (PR-A8U)
+04096 - Footwell light with LED technology (PR-QQ1/QQ3)
+08192 - SAFE-function deactivated (PR-A8U)
+16384 - Fuel filler cap recognition (PR-A8U)
+32768 - Interior monitoring (PR-A8U)
Now to select which items we want to add and how.
Example: By deleting the stored value and replacing it with 15, we can now operate the opening and closing of the windows and sunroof by pressing and holding the lock or unlock buttons on the key fob.
Control module adaptation
Select Controller 46 (Comfort System) and the #10 (Adaptation)
-> Channel 61 (Comfort Functions)
+001 - Comfort closing for window regulators via remote control
+002 - Comfort opening for window regulators via remote control
+004 - Comfort closing for sunroof via remote control
+008 - Comfort opening for sunroof via remote control
+016 - Comfort closing for window regulator via switch drivers door
+032 - Comfort opening for window regulator via switch drivers door
+064 - Comfort locking for sunroof via switch drivers door
+128 - Comfort opening for sunroof via switch drivers door
+256 - Comfort closing for window regulators via lock cylinder
+512 - Comfort closing for sunroof via lock cylinder
-> Channel 62 (Central Locking Functions)
+1 - Central locking closed turn signal recoginition
+2 - Central locking open recoginition
+4 - Terminal 87 USA logic
Central Electronics - Control Module #9 (Cent. Elect.) under the tab Electronics 1
Begin by selectting Controller 09 (Cent. Elect.) and choosing function 7 (Recode)
Example: by entering the code 11111 on most 2004 models, we can now have the foglamps to illuminate without having the main beams on.
?xxxxx: Footwell lighting
0 - Footwell lighting with halogen lamps
1 - Footwell lighting with LED lamps
x?xxxx: Type of headlight
0 - Halogen headlight
1 - Bi-Xenon headlight
xx?xxx: Automatic Headlamps
0 - Without Automatic Headlamps
1 - Automatic Headlamps without Rain-sensor (Most 2004)
2 - Automatic Headlamps with Rain-sensor (Late 2004 and later)
xxx?xx: Daytime Running Lights
0 - Without DRL
1 - with DRL
xxxx?x: Type of Daytime Running Lights
0 - DRL not selectable over MMI
1 - DRL selectable over MMI
xxxxx?: Land selection
1 - Remainder of the world (RoW)
2 - Remainder of the world/north countries (Finland, Sweden, Norway) *Note: The exterior lights will be on continuously and only fog lamp changes can be made with the light switch.
3 - The USA
4 - Canada * Note Parking lamps and fog lamps will be active whenever the ignition is on or the headlamps are activated by the sensor or turning the headlamps on via light switch.
5 - Denmark
6 - Italy
0 - Germany (km/h)
2 - USA (US - mph)
0 - Without DRL
1 - with DRL
3 - The USA
5 - Denmark
6 - Italy
2nd tire size is interesting...
If you wanted to fit large wheels and oversized tires - with a larger tire OD for ride quality and gas milage... Wonder how large a tire OD you can dial in?
Im not quite sure about that one part...
Note the binary value of 16...Well all of our cars are quattro. I have TPMS. According to that coding I should have a value of 17 but mine was set at 16 from the factory.
awdinut
32
09-03-2016 04:38 PM
cameltrophyallroad
Audi allroad
02-14-2016 07:18 PM
KevinLugnuts
11-27-2015 04:43 AM
