Ready to change my upper control arms
#51
Takes no time....
#52
Check Karlyn CA after 2 years and still GOOD...
I got new tires and my tire worn out so badly inner/outer. Before I replace my new tires, I wanted to make sure my Karly CA are bad as the right ones after 9 mos. According to MP4.2 suggested that could be CA, but I've never had alignment after replacing them on MAY 31, 2015. The amazing results were that both of my Karlyn CA are still GOOD. So it must be the alignment. I think the ones that were bad after 9 mos due to incorrect CA height adjustment, the bushing had to much stress on it. Now, I'm ready to take it to the Shop and have the new tires put on and have alignment done. One thing about the alignment, I talked to the manager of WheelWorks here in Newark, he's not sure if he has to drop the subframe to adjust the alignment. I insisted that it's the right way for our Audi A8, he got nervous and ensure that he will look at the car before he work on it. I was glad he's honest.
Cheers,
Louis
Louis
#53
I replaced my upper control arms this weekend. I did not have too much trouble with the pinch bolts despite this being the first time they have come off in 13 years on a midwest car. What I did have a crazy amount of trouble with were the post on the ball joints that go into the knuckle. I could not tap them out. So I got some ball joint separator forks, and managed to get them half way out, at which point the fork was in as far as it would go. This unfortunately destroyed the boots. I still could not tap them out, even after heating up the knuckle. Then I got on kind of adjustable separator press, which fit on the front control arm joint but not the rearward one. Then I got another type ball joint separator. I had to put a lot of force on that one too... then everything thing just comes apart in an explosive burst of potential energy turning into kinetic energy. Anyway, I'm just writing this to give people a heads up about what tools to have on hand, as, its not just the pinch bolt that may get you. Have a ball joint separator like the one below on hand, and maybe even some separator forks.
Milpower
09-16-2008 07:30 AM
thewatcher101
09-30-2007 05:36 AM
Oettinger_A4
12
07-11-2006 11:45 AM
sk88erguy
02-14-2005 02:11 AM
maggio
06-11-2003 07:03 PM
