Replaced front shock, now having lifting issues
#11
no sir i did not, i attempted to find it prior to changing out the shock to put it in jack mode but discovered i was sol, any thoughts on the random over inflation
#12
There are more leaks in the system.
Need to get the system connected to the MMI to set to lift mode, then jack mode, leave it sit for a few minutes, hours or days depending upon how slow/fast of the leaks. The struts that fail will sag independently. If both front or rear or all went down, it's the valve block. The valve block leak will lower both front or rear and not independently,
Simple test and pretty accurate to find the problems and it's never the pump as many uninformed, illiterate mechanics would recommend or the rebuild kit people would love to sell, cheap and wishful.
Watch my videos on how I troubleshot mine.
#16
#17
Plan ahead on what you want to do with your new A8, if you want to have entertainment system like mine, get 07 or 06. 04 doesn't have better updated electronic stuff, it's the first year for D3.
#18
Mileage doesn't really mean much, I would buy Mr. Bally's 230k+ miles not km over any unknown 100k miles. It's the owner, how well they keep the car, how abusive they are... The problem with A8 D3 is that they look so good, you can't tell if it's abused or mishandled. One mistake made by a mechanic, the car is wounded for life. What's made to fail, will fail, just a matter of time. I do take care of my car and drive it nicely and things still break when time comes, and it's in the best weather and garage most of its life.
I would buy a car if it's all original and driven nicely, original suspension should last a long time, I don't want some shady mechanic changed the suspension with unknown rebuilt parts and break the car due to mishandling the replacement. It cost me $250 for a new Chinese made bag and it works perfectly, yes, I'm rolling the dice due to low quality control but at least it's new, airbag is not rocket science, a bag to hold some pressure, expand and contract as air pumps in/out. The leaks are mostly at the clamped section. You get one that clamp put on correctly, it would last for life.
Find the right car, watch my video on how to check the car before picking it up.
Read my post on how to find the best D3. I always research before buying.
Cheers and good luck,
Louis
Louis
#20
Louis
Louis
