RMT Air suspension leaks again.....
Well after 8 months, my front suspension, in which the rebuilt struts are from RMT, is leaking again. I noticed the green lowering light when coming into the driveway yesterday. I tested by placing the car in jack mode. Came out today and front was completely on bumpstops. When I called them, they suggested that I check the valve block. But there are no codes. They also stated they have no cores, so I would have to send some in and be reimbursed. I really hope they can work with me on this.....I really don't want to give a bad name to them....
I really doubt it's the valve block. The rear is totally fine. From the looks of it, it seems like the drivers side is the culprit as its lower than the passenger side. I had taken a 3 week trip and when I came back, the rear was at normal height but the front was down. I'll use RMT again since I have a lifetime warranty with them.
But I really hope this is the last time. If not, this car is going to another home....
For what it's worth, when I had to replace mine the rear didn't sag either. I did the same jack mode + soapy water tests on the front struts, which didn't show any leaks. Valve block seems to hardly ever fail though, from what I remember. If it is the strut, maybe they'll send you one first and let you send the faulty one back so you're not waiting too long.
Yeah I'll definitely keep that in mind. I noticed the drivers strut is dropping down pretty fast after engine shut down. It noticed it takes about 5 or so hours to noticeably drop. We will see in the incoming week
I'm starting to regret my rebuild. I sent all 4 non-leaking struts in to be rebuilt, as preventative maintenance. So far, the fronts aren't leaking, but I have had to return the rears twice. The first time was due to bad packaging, where the reservoir mounts punctured the boots. After installing the rears, they have both leaked at the very top. Passenger side was bad enough it wouldn't even pump up. Drivers side leaked down in about 1 minute. I don't know how they could have missed leaks like these if they were tested.
I've used them once to replace a drivers strut, the one they had sent was leaking. It was leaking at the brass air inlet fitting. Also, I was concerned about the studs that mount to the strut hat, they were much shorter that the original one. I could only get about 3 threads on the nuts. I called and told them and they sent a replacement one right away. The one they sent has been installed for about 1.5 years and still working fine. I thought to myself that maybe It was a one off case, but after seeing numerous complaints on their reliability im not too sure. Their customer service was good though. (Im knocking on wood for know)
