Rotors that don't need replacing?
Hey all,
Any aftermarket rotors out there that dont require replacement? One of the more annoying things about owning this car is the fact that I have to spend a few hundred extra $ for every brake job because of this. I'd like to avoid it, any options out there that are priced reasonably? Thanks |
Not possible.
Originally Posted by mishar
(Post 24409295)
Not possible.
lol I thought this was a joke as I read it....
You could always go carbon ceramic brakes and only change them ever 150-200k miles! But it'll run you $x,xxx dollars......! (This is a joke don't take it seriously). On my 05 A8 in 50k miles I bought the car with already used brakes and rotors and have only changed new pads and rotors once and I'm at 110k on that car now. You drive a flagship sedan quit complaining about things that are common to replace on just about every car ever! I don't enjoy taking showers, shaving, going to work, taking the gf shopping; but their all things that are annoying but necessary... |
You shouldn't have to replace them every time. Aside from that you are just going to have to lay out the cash or get a different car.
Originally Posted by kgd_007
(Post 24409319)
Turns out the rotors are fine all around and all I need to replace is the front pads. But with the cost of front pads and with the rotor being past half it's life (roughly), I didn't want to risk squealing pads or having to replace the rotors before the pads have to be replaced. Since you wouldn't put used pads on a new rotor. Also didn't want to have my rotor refinished (turned) although I could have done it myself with some time and sandpaper. I will be posting my nice new setup soon. |
FWIW, my W12 calcs are roughly 75-80K miles...
on the rotors before they go under the min spec. I'm alternating between the original factory set and a drilled set (which used OE blanks), so have pulled and mic'ed each on the most recent DIY brake jobs. In simple terms, rotors should run through two pad sets, and definitely not just one. My driving is suburban mixed stop and go and freeway, and definitely somewhat spirited.
Also, unlike most all my prior Audi's on this one the front and rears wear similarly--both pads and rotor percentage--instead of the backs a lot less than the fronts. |
Originally Posted by MP4.2+6.0
(Post 24409342)
on the rotors before they go under the min spec. I'm alternating between the original factory set and a drilled set (which used OE blanks), so have pulled and mic'ed each on recent DIY brake jobs. In simple terms, rotors should run through two pad sets, and definitely not just one. My driving is suburban mixed stop and go and freeway, and definitely somewhat spirited.
Originally Posted by Brozee
(Post 24409321)
turned without removing...
(Post 24409349)
Man be serious. It is not really good, nor easy done on a lathe, even grinding machine.
Did not take very long to do and the brakes are PERFECTLY smooth. Of course it remains to be seen if they warp more quickly due to having less mass to disipate heat. Although they only removed about one half mm of thickness. I didnt even know such a machine existed. They say its better when done on the car because it compensates for any variables in the hubs, etc. |
