S8 caliper anti rattle clips P/N? + Pics of my A8, 22's etc..
Hi, everyone, long time reader, first time Poster. I will be having my calipers powdercoated, and im having trouble finding the PN for the S8 anti rattle clips. I do know that they can be bought as a separate part, and can be used with 04 model year calipers. I've seen other members on other forums with this mod, any help would be appreciated.
PS: my car is a 2004L, VagCom Lowered, Magnaflow exhaust (sounds real nice and stealthy), running 22x10.5 rear, 22x9 front, with Nitto Invos, and a "ebay" lip spoiler that was painted to match..
Car looks nice, any way for you to post a better pic of that rear lip, I was thinking of getting one of those on my ride. What's the setup on that exhaust, just mufflers? Thanks
The offset is 35et on both front and rear. And no, just vagcom lowered as of now. I will be going 1/2" lower via lowering links soon. And no, no rubbing issues at all. Keep in mind I chose a 275/30/22 in the rear and a 255/30/22 in the front. A 285 in the rear on a 10.5" wheel might rub or be pretty damn close to the inner wheel liner.
As far as the Magnaflow's I kept all the stock piping and just swapped out the mufflers. It gives the exhaust a much better tone. Nothing too loud. Sounds real nice if you step on it. And no loud drone at hwy speeds.
Don't want to rain on your parade. This is my opinion only; don't take offense but I think your rims look a bit ridiculous placed on an A8. They may look at home on a Lincoln LS or an escalade but they are like a 5'8 man with size 14 shoes...
Funny, I also had a Lincoln LS back when I was 16, on 20's lowered, custom everything. Wheel's look alot bigger than they really are because they have no "lip". The stock 18's looked way to small for a car that size. I think 20" wheels look best, on a A8, for a clean oem look. I originally wanted the 21" MTM but for 8k, nah, so I got these for 1400. Im a fan of bigger wheels, some are not, to each his own.
How is the ride quality with them? I would never run them in Michigan, but was on the border of getting 20" for the months without snow. Did you have to raise the car at all or do you just have it running in "comfort" mode to have it raised so it doesn't rub?
I don't like how it looks, but that's not important. That's only meter of taste. A bit more important are facts that wider rear tires on a nose heavy car just improves under steering, that there is difference between front and rear diameter what makes mid differential to work overtime and that's one with limited slip, that they are quite larger than OEM what makes speedometer inaccurate and combined with larger rims kills performance and finally 30's profile kills ride quality.
Ride quality is not that bad as expected. Not much worse than running the stock 18's at max psi. And I always drive with the suspension in "dynamic" mode (keep in mind I am lowered max allowed through VagCom, so the suspension is a bit stiffer) and have no rubbing issues at all. I took alot of measurements to calculate which tire would be best to not rub, and bit my nails until the tire shop set my car back on the ground, and cleared. And yeah, I wouldn't ride a set up like this if I were in Michigan. I have been to Marquette in winter, and the roads are rough. I live in Southern California, so it's 70 year round, and luckly don't take many rough roads.
