Soft Close Trunk Fix (Update)
For those of you having trouble with your trunk closing, even with the updated motor, you may have a missing spring in the soft close striker and catch. A write up to the fix can be found here:
https://www.audiworld.com/forums/a8-...ishar-2866079/
One thing I noticed missing from the write up is if you weren't lucky enough to have the spring somewhere in the trunk, as was my luck, you basically had to buy a new latch. Luckily my local Home Depo had a small packet of springs which contained a spring that works perfectly (smaller of the two types). So instead of spending $296.24, you will only spend $3.72. Whether or not the spring will hold up, will be determined in time.
Spring links: https://www.homedepot.com/p/Everbilt...6086/202045462
ltooz_a6_a8_q7
03-12-2017 01:40 PM
mAgnum8
02-28-2009 11:11 AM
englsh
12-04-2004 12:34 PM
