Steering wheel heat malfunction
2005 Audi A8 Quattro with only 54,000 mi.
Steering wheel heat malfunction.
1.) Does anyone know if there is an easy fix for this. Is there a possible way to disable the heated steering wheel? Or is there any trick to turning it off? I pulled out the #6 fuse, but that causes other issues as well, turning signals, driver airbag, parking break, headlight auto adjust etc.
2.) Repair?
can I disable it, or...
is it a simple wiring part fix or...
will I need a whole new steering wheel?
2.) Repair?
Funny, but I never realized I had a heated steering wheel until 10 years later. A couple of days ago It almost burnt my fingers off, and it started to smell like melting leather/ plastic. I located the button for it just behind the steering wheel adjustment wheel, but it doesn't seem to turn off when pressed. as I mentioned I removed the fuse#6 just so I could run short errands. Although the car is 10 years old, it only has 54,000 miles on it and I am the original owner. it's only worth 7-8 thousand and rather than spend $$$$ I would love to know if there may be a way to just bypass it somehow. I do need to put the fuse back in since it also affects other parts of the car.
Hello,
Please post a picture of the button that you say you pressed to turn on the heated SW, as my 05 A8L W12 does not have a button to activate the heated SW, my HSW is activated by turning on the driver's side heated seat per the HVAC controls, the button next the steering wheel adjustment is for exit mode of the steering column.
AudiWorld Wiseguy
That button by the steering column adjuster is to turn on/off the convenience access function. Nothing to do with wheel heating.
Steering wheel heat is only activated with seat heating, but then only when cabin temp is below 50F (or something like that).
If you have a systems malfunction causing the wheel heat to be on permanently, then I suggest unplugging the wheel heater element. You need to remove the airbag module to get to the connector. Easy job, two screws.
Your car is worth plenty more than 7-8, by the way. 13-14k, private party for having that low of mileage. If you haven't done the timing belt job, I'd start looking at it. You aren't there for mileage, but the age concerns me. For your steering wheel, I don't know why it would fail on, but I suspect a short of some kind. Whenever I see weird electrical faults, I always have to suggest checking to make sure your floor boards are not damp. A water intrusion can cause all sorts of problems.
