Sponsored by:
Sponsored by:
Anyway to auto dip the Driver's door mirror when reversing?
Old 01-17-2008, 07:16 AM
New Member
brucetimev8's Avatar
Default Anyway to auto dip the Driver's door mirror when reversing?
Can this function be programmed? The passenger side mirror dips automatically in reverse, but I would also like the driver's side to do the same.
- Bruce
Old 01-17-2008, 07:57 AM
tcr20's Avatar
Default I think on the 2008, if you turn the control **** to the left, the same will happen with the left
mirror when you put it in reverse.
Old 01-17-2008, 08:08 AM
New Member
Mine's a 2005 model...is there a still a way?
Old 01-17-2008, 08:52 AM
tcr20's Avatar
no idea, check the manual?
Old 01-17-2008, 01:32 PM
knepster1's Avatar
Default Re: no idea, check the manual?
Only passenger side. You can set both mirrors down and save it in one of the 1-4 memory positions on the door and press that number when you are reversing and then press the original number set up when done.
Old 01-17-2008, 01:52 PM
Emauss's Avatar
Default Along these lines...is there any way to have the mirrors AUTOMATICALLY fold..
..when I park?
Old 01-17-2008, 01:53 PM
Emauss's Avatar
cute work-around!
Old 01-17-2008, 02:39 PM
New Member
Default LOL! That's what I've been doing! So I figure the car has all the electronics, should be a
way to automate it. :-)
RHD A8's have "our driver side" mirror dip, so it's gotta be programmable somewhere(?) Vag-com setting maybe?
Hasn't someone hacked into the A8 yet! :-)
Old 01-17-2008, 05:56 PM
MP4.2+6.0's Avatar
Default You're on the right track...?
Tell VAG COM it is a British spec car? Of course then it would overheat and MMI would instantly crash and the mirrors would stop working completely, so maybe not.
I like the set the door switches idea. That's a new ingenious tip.
Old 01-17-2008, 06:04 PM
dtwa8's Avatar
Default Re: I think on the 2008, if you turn the control **** to the left, the same will happen with the lef
My 2008 does not do this ... I think you can still only set the offside mirror to dip. But knepster1's workaround below is pretty good!
Quick Reply: Anyway to auto dip the Driver's door mirror when reversing?
