Things I've Done With My Audis Over The Years... AudiWorld...
Sometimes when I read about people with car troubles, they come up here but they never get the "pertinent answers" and they get the run around, I do feel for their frustrations, because I've been there. If everyone who did something, make a thread, list all the things they worked on and posted... put it under their signature, all they need to do is "read my signature for your problems"... It would be nicer than "google me". When my car is stuck on the freeway, at night, in heavy rain or snow, I would be panic, and I sure wouldn't like someone telling me to google the darn problems. It takes a little time to go to my CP -->statistics --->Find all threads started by me. Now the keyword is started by me. I know I don't fix as many problems as many supper users here, therefore it only takes 15 minutes. Anyhow, my point is if someone has done something, and the list is in the signature, it's easy to refer to people who are in urgent need to read right away, it's more helpful that way.
NextGen OBDEleven Pro: https://www.audiworld.com/forums/a8-...s-ios-3003431/
2019 A8L 55 3.0T D5:
Oil Change: https://www.audiworld.com/forums/a8-.../#post25862617
2011 Q5: Install Apple CarPlay on MMI 3G Plus Q5 https://www.audiworld.com/forums/q5-...3g-q5-2981907/
MMI 3G Plus Jukebox: https://www.audiworld.com/forums/q5-.../#post25382805
2016 Q5:
Modify AMI cable to stream audio from Bluetooth and USB flash drive: https://www.audiworld.com/forums/q7-.../#post25033071
Add Back Up Camera to 2016 Q5: https://www.audiworld.com/forums/q5-...emium-2901469/
Modify AMI cable to stream bluetooth with all Phones: https://www.audiworld.com/forums/q5-...ongle-2888575/
2006 - A8L:
How to restore the sound from component protection on 4E0035729A: https://www.audiworld.com/forums/a8-.../#post25437854
Replace Audi A8L D3 Windshield Wiper Blades: https://www.audiworld.com/forums/a8-.../#post25432384
Optical CD Auxiliary Box for MMI 2G :https://www.audiworld.com/forums/a8-.../#post25427167
What you should/must know about Audi Adaptive Air Suspension: https://www.audiworld.com/forums/a8-.../#post25427641
Left air suspension failed at 131k miles: https://www.audiworld.com/forums/sho....php?t=2984544
MMI 2G iPod Interface: https://www.audiworld.com/forums/a8-...ost25375663Fix
sunroof drainage problems: https://www.audiworld.com/forums/a8-.../#post25355750
Trunk Lid Leaks : https://www.audiworld.com/forums/a8-...k-lid-2966570/
Wonderful 6 years : https://www.audiworld.com/forums/a8-...4-2-a-2964493/
Fix Navigation DVD "Please Check Navigation DVD" : https://www.audiworld.com/forums/a8-.../#post25228506
Apple CarPlay for MMI 2G: https://www.audiworld.com/forums/a8-...mi-2g-2960463/
Fix Broken Glove Box Frame: https://www.audiworld.com/forums/a8-...frame-2960370/
OBDeleven for Android vs VCDS for Windows: https://www.audiworld.com/forums/a8-...eople-2945231/
Apple CarPlay Apps vs Mirroring: https://www.audiworld.com/forums/a8-...mi-2g-2947936/
Attempt to fix the door lock switch button NOT working: https://www.audiworld.com/forums/a8-.../#post25176974
Heat comes out of left side vents instead of AC cold air fixed:https://www.audiworld.com/forums/a8-...-cold-2946211/
How to search Audiworld: https://www.audiworld.com/forums/a8-...oblem-2944201/
123k Mile Oil Change : https://www.audiworld.com/forums/a8-...again-2943414/
How to update 2016 Navigation DVD on MMI 2G: https://www.audiworld.com/forums/a8-.../#post24990763
How to Eliminate Audio Ground Loop Noise from USB charger: https://www.audiworld.com/forums/a8-...-cars-2919822/
Unclogged AC Drain-Water Under The Carpet: https://www.audiworld.com/forums/a8-...arpet-2917541/
How To Disable MMI Screen Motor: https://www.audiworld.com/forums/a8-.../#post24945952
Battery System Failure: https://www.audiworld.com/forums/a8-.../#post24944829
Fix Soft Close Trunk Lid NOT Closing - Broken latch spring: https://www.audiworld.com/forums/a8-.../#post24936030
Fix A8L Front Air Spring Suspension Low To Ground Due to Strut Leaks: https://www.audiworld.com/forums/a8-...rider-2913592/
How To fix 00819-High Pressure Sensor (G65) AC NOT cold:https://www.audiworld.com/forums/a8-...r-g65-2900106/
How NOT to depend on VCDS and replace wrong Parts in MMI 2G: https://www.audiworld.com/forums/a8-.../#post24817727
How to install Analog TV Tuner: https://www.audiworld.com/forums/a8-.../#post24814893
How to install ElsaWin 5.x on Windows 10: https://www.audiworld.com/forums/a8-...-10-a-2900642/
How to remove the trunk lid trim: https://www.audiworld.com/forums/a8-.../#post24488995
How to enable Hidden Menu: http://www.dognmonkey.com/audi/how-t...sing-vcds.html
How to use Rapberry Pi 2 to play video and music through MMI 2G: https://www.audiworld.com/forums/a8-...mi-2g-2896771/
How to fix dash board LED indicator lights OUT: https://www.audiworld.com/forums/a8-.../#post24772086
Modify AMI cable to stream bluetooth with all Phones: https://www.audiworld.com/forums/a8-...ongle-2888574/
How to use owner manual on MMI 2G: https://www.audiworld.com/forums/a8-.../#post24722843
Use VCDS software with Mac OS X:https://www.audiworld.com/forums/a8-...s-now-2885737/
Replace A8 D3 Keyfob Battery: https://www.audiworld.com/forums/a8-...ttery-2885235/
Pair iPhone 6: https://www.audiworld.com/forums/a8-...8l-d3-2881478/
Replace upper control arms: https://www.audiworld.com/forums/a8-.../#post24691483
Replace weak hood shocks : https://www.audiworld.com/forums/a8-...hocks-2883762/
How to find the best used D3: Looking For The Best Used A8 D3 - AudiAudi
Picked up my 2006 A8L: https://www.audiworld.com/forums/a8-...y-omg-2844754/
105k miles service https://www.audiworld.com/forums/a8-.../#post24682586
Connect Android & iPhones to AMI via Bluetooth for $13:https://www.audiworld.com/forums/a8-...essly-2881790/
A little check list before taking delivery: https://www.audiworld.com/forums/a8-...ivery-2880586/
Add Analog TV: https://www.audiworld.com/forums/a8-...tions-2851607/
Watch TV on MMI 2G: https://www.audiworld.com/forums/a8-...mi-2g-2852242/
Remove Trunk Motor: https://www.audiworld.com/forums/a8-...motor-2848684/
Fix A8 Weak Trunk: https://www.audiworld.com/forums/a8-.../#post24466998
Swap Q5 Wheels On A8L: https://www.audiworld.com/forums/a8-...y-a8l-2872344/
Close A8L Trunk w/ Key Fob: https://www.audiworld.com/forums/a8-.../#post24572167
Back Up Camera Retrofit: https://www.audiworld.com/forums/a8-.../#post24441366
Replace Front Brake Pads A8L: https://www.audiworld.com/forums/a8-...sport-2849517/
Replace Rear A8L EPB Brake Pads: https://www.audiworld.com/forums/a8-...6-a8l-2866173/
Update MMI 1190 to 3360: https://www.audiworld.com/forums/a8-...ab-cd-2844972/
Update MMI Software 3360 To 4610: https://www.audiworld.com/forums/a8-...1-cd2-2845498/
Instrument Menu Gone after MMI update : https://www.audiworld.com/forums/a8-.../#post24429406
Change My Oil A8L: https://www.audiworld.com/forums/a8-...miles-2862627/
LEDS Retrofit: https://www.audiworld.com/forums/a8-...6-a8l-2847902/
"Please Check Navigation DVD": https://www.audiworld.com/forums/a8-...n-dvd-2865346/
Add Freon To A8L: https://www.audiworld.com/forums/a8-...-cold-2868791/
MMI Screen Is Black: https://www.audiworld.com/forums/a8-...-help-2867744/
CP-Component Protection? https://www.audiworld.com/forums/a8-...vices-2857532/
Programming Homelink: https://www.audiworld.com/forums/a8-...mming-2844894/
2008 - Q7
Replace Left Mirror Motor: https://www.audiworld.com/forums/q7-.../#post25567094
Replace brake pads and rotors @62k miles: https://www.audiworld.com/forums/q7-.../#post25541766
Apple CarPlay and Android Auto for 2008 Q7: https://www.audiworld.com/forums/q7-.../#post25310287
Modify AMI Cable to Stream Audio with $10 30-Pin Bluetooth Receiver: https://www.audiworld.com/forums/q7-...eiver-2951026/
Tranfer songs and playlists from iTunes to USB drive: https://www.audiworld.com/forums/q7-.../#post25047507
Change Oil On 3.6L FSI Engine: https://www.audiworld.com/forums/q7-.../#post25042293
How to Eliminate Audio Ground Loop Noise from USB charger: https://www.audiworld.com/forums/q7-.../#post24963554
Modify AMI cable: https://www.audiworld.com/forums/q7-...ne-q7-2889268/
Enable Voice Commands: https://www.audiworld.com/forums/q7-...ation-2852453/
Navigation Retrofit: https://www.audiworld.com/forums/q7-...24200-2853272/
Prepare Q7 For Snowy Sierras: https://www.audiworld.com/forums/q7-...-year-2876514/
Fix Squeaky Doors: https://www.audiworld.com/forums/q7-...doors-2868145/
2004 - A4 Cabriolet
Oil Change 3.0L V6: https://www.audiworld.com/forums/a4-.../#post24302715
Replace Spark Plugs 3.0L V6: https://www.audiworld.com/forums/a4-...ement-2843924/
Replace Battery: https://www.audiworld.com/forums/a4-...ttery-2845874/
Top Doesn't close-no power trunk: https://www.audiworld.com/forums/a4-...fixed-2848033/
ESP light-rough idle: https://www.audiworld.com/forums/a4-...y-fix-2834447/
Replace Brake Light: https://www.audiworld.com/forums/a4-...-bulb-2818202/
Battery Died Overnight: https://www.audiworld.com/forums/a4-...night-2817412/
Error 02000 Switch position: https://www.audiworld.com/forums/a4-...fixed-2807637/
Programming Homelink: https://www.audiworld.com/forums/a4-...codes-2806042/
Antenna problem fixed: https://www.audiworld.com/forums/a4-...fixed-2806596/
Symphony II Problems With Antenna On A4 Cabriolet - AudiAudi
error 02000 switch position- 008 implausible signal fixed: https://www.audiworld.com/forums/a4-...fixed-2807637/
Replace MAF (generic vs Hitachi):https://www.audiworld.com/forums/a4-...-3-0l-2864860/
1996 - A6 Avant
No Heat: https://www.audiworld.com/forums/aud...er-a6-2145805/
https://www.audiworld.com/forums/aud...again-2148111/
Sunroof Gears & Rails: https://www.audiworld.com/forums/a8-...fixed-2836462/
Replace Valve Cover Gaskets: https://www.audiworld.com/forums/aud...asket-2837521/
Replace Windows Regulator Dorman: https://www.audiworld.com/forums/aud...embly-2853871/
Sparkplug popped: https://www.audiworld.com/forums/aud...perts-2779836/
Replace Rear Brakes: https://www.audiworld.com/forums/aud...g-now-2143620/
Fix Engine Rough Idle, Stall At Stops, Sluggish Acceleration - AudiAudi
Ignition lock stuck fixed: A6 Ignition Lock Stuck Fix - AudiAudi
Dome Light Cover fixed: A6 Dome Light Cover - AudiAudi
2.8L V6 Oil change: A6 C4 Oil Change - AudiAudi
Temperature Sensor: A6 Temperature Sensor Replacement - AudiAudi
AC controller bulbs replacement: A6 C4 AC Controller Bulb Replacement - AudiAudi
Tailgate vacuum lock leaks fixed: A6 C4 Avant Tailgate Vacuum Lock Fix - AudiAudi
Instrument Bulbs replacement: A6 C4 Instrument Bulbs Replacement - AudiAudi
1998 - A8 D2
Coolant leaks-Oil Cooler Pipe: https://www.audiworld.com/forums/a8-...-pump-2757129/
Clean Tan Leather: https://www.audiworld.com/forums/a8-...ather-2860507/
MAF Sensor - Signal Too High: https://www.audiworld.com/forums/a8-...-high-2793109/
Remote KeyFob Programming: https://www.audiworld.com/forums/a8-...mming-2792300/
Replace Waterpump Without Removing Timing Belt: https://www.audiworld.com/forums/a8-...-belt-2753550/
Thermostat Replacement: https://www.audiworld.com/forums/a8-.../#post24002266
Cigarette Lighters No Power: https://www.audiworld.com/forums/a8-...power-2750491/
2016 Q5:
2006 - A8L:
2008 - Q7
2004 - A4 Cabriolet
1996 - A6 Avant
1998 - A8 D2
Great idea but....
May I make a suggestion.
If you were to make a separate thread that listed all the great things you have done then just put a link to that as your signature that would prevent threads getting overloaded with massive signatures.
It's one of my pet hates of forums, huge signatures with huge pictures that make a thread tedious to read.
What do you think?
What do you think?
On your specific pet peeve...suppressing auto signature display
Without commenting on Louis' post or concept, on your specific "pet hate," you can have your personal cake as you like it:
Pull down User CP link toward left side about ¼ of way down main post screen.
Now "Your Control Panel" appears on left edge
Go down to Settings & Options/Edit Options
Scroll way down to Thread Display Options. In first rectangular box, unblock the Show Signatures button (or other choices as desired).
Be sure to scroll to bottom and click Save Changes radio button.
Presto, no more signatures stuff, for better or for worse.
It was a dig at Louis
I am sorry if it came over like that.
I understand what you said about turning off signatures but that would then prevent me to see his invaluable advice.
I was nearly trying to recommend a link in the signature to a index like thread to provide the means of access to the vast amounts of knowledge with out overloading normal topics with repeating text.
Again please accept my apologies if it seemed like I was have go at Louis.
Presto, no more signatures stuff, for better or for worse.Now "Your Control Panel" appears on left edge
Wir fahr'n auf der Autobahn
07-21-2000 07:25 AM
