Tune2Air/Streaming Question
#11
Do these $80-90 bluetooth let you to control the phone or the songs
from the MMI screen? If not, just stick a $5 Audio bluetooth on the cigarette lighter and plug in you Auxiliary cable to the bluetooth, mount your phone on the dash and use siri to change songs.
Cheers,
Louis
Cheers,
Louis
#12
Im not sure why, but my last post didn't go through so here goes again I don't have an iPod cable from my AMI, i just have an AUX. I dont think that it is possible for me to control the phone through my MMI, since it is too old, so im not sure that we have the same version MMI/AMI. When I connect my Tune2Air, it doesn't even power on, but if i connect it to the 12v via a USB cable, it does, and my phone can connect to the Tune2Air. But the MMI still says "can't connect..." and doesn't recognize the Tune2air.
#13
Please take the picture of your AMI... Aftermarket?
Cheers,
Louis
#15
Club AutoUnion
#16
I had the same problem where the Tune2Air wouldn't power up, even sat with the Audi mechanic while he tried to get it to work for 30 minutes. With some research I found that the Aux wont power unless it sees an ipod connected. I went to A2DP4AUDI and talked to Rich, he steered me to the combo deal blue tooth adapter and the hardwire power kit. Took about 20 minutes to install, no cutting or complicated install. Works perfect, streams music from my android. You have to use the AMI cable that comes with the blue tooth adapter, don't use the factory Audi AMI cable it does not work with this kit.
Add Bluetooth A2DP Streaming to your Audi - A2DP4AUDI - Audi Bluetooth Adapters
#17
+1 on A2DP4AUDI in a MMI 2G vehicle. Works and sounds great in my 05. There is no +12v supplied by AMI when using an AUX cable, so you need to bring power to the music device by another means. I used the hardwire kit from A2DP4AUDI and tapped into a switched +12v line in the passenger side fuse box. It also requires a wiring change to the AUX cable, which I did myself, or you can buy the already-modified cable from them.
#18
If anything cost more than $15 to stream music without
Forget the AMI.
Cheers,
Louis
#19
#20
I tapped into number 46 on the fuse panel and ran the wires behind the glove box. There is a pre cut hole in the back of the AMI insert module in the glove box that the USB power plug on the hardwire power kit will just fit through.
