V10 intake manifold
V10 intake manifold
Doing carbon clean on the long easter week end and a small plastic tumbler, i supose, fell out of my intake when i turned it over on the work bench so i guess i'm in need fore a new one.
Is Jim ellis the cheapest way to go at 1764$ or anybody know one at a lower cost?
Car is '08 S8
Car is '08 S8
Audiworld senior member
Car is '08 S8
Car is '08 S8
Did you also check the inside of the manifold with a camera probe to figure out where this part came from. Seems very extreme solution you have to buy a whole new manifold due a plastic part that broke of.
No, i went with brake cleaner soaking them for 30min each than drill with zip ties for the big gunk, wash dry with brake cleaner, scrape dry carbon with screw driver then big pic, than small pick, and finish off with brake cleaner on tooth brush. Once the primary soaking is done takes me around 10 15min per hole and end result is perfect.
After reading your post i had descide to reinspect the intake more carefully and whil inspecting it a flap fell out of it so back to purchase on a new one.
So they still are the lowest costing ones over Jim Ellis at 60$ - with shipping quote but still a big chunk of money at 1719.90$ before 163$ shipping quote.(roughly 2500$ cad for me at the current rate + 10% taxe on that upon reception).
Car has 140k km and i suspect cleaning has already been done before. Now trying to get the injectors out so can get them cleaned.
Sorry only bad cell pics.
Don't risk damaging the O rings by removing the injectors, instead just clean using PEA with something like Redline SI-1.
If you don't mind sacrificing torque over 4K RPM (4.5K under load), some people have just removed the broken intake flap system.
Here's a tool to make sand blasting easier, etc.;
http://www.audizine.com/forum/showth...eaning-Adapter
https://www.audiworld.com/forums/a8-...intake-2943261
https://www.harborfreight.com/portab...kit-37025.html
