Valve cover gasket availablity
I am trying to replace both of my valve cover gaskets on my 2007 A8L 4.2 and have been informed by my Audi dealer that the left side is not available by itself any longer; they are telling me that I have to purchase a new valve cover to get the gasket! Which cost around $700....Does anyone on here know if I can get just the valve cover gasket and what the part number is for a 4.2FSI? I can't believe that this is the case seeing that this engine was not only used in the A8, but other Audi vehicles as well. Or if there is a recommended aftermarket gasket I could go with? Thanks!
Try ECS Tuning's site.
Also note that when parts are superseded, a lot of time the VW/Audi PDC sells the old stock to Auto Wares or Rock Auto. They then offer the original stuff at decent prices.
Mike, what you are describing is what happened with the D3 S8 for the early ones. The S8 covers are plastic with a paint job as I understand them, and apparently the early design warped. I haven't heard that was the case for the 4.2FSI, but I suppose it may be so there too. What folks were doing on the D3 S8 was buying the gasket for the other side and then modifying it to fit. There may be some posts or videos for that. Not sure of how 4.2 FSI gasket set up looks. On my C5 port 4.2, both sides were the same since all Audi did on those was flip the head for one side vs. the other and then swap the cam gear and timing adjustment stuff using already milled cut outs. Remember C6 A6 4.2 (2006 forward I think) is basically the same FSI motor so you could try listings or posts/videos for that since it was probably sold in more volume. Old Q7 4.2 I think too.
Since this engine was used in several Audis, I cannot see why I have not located a valve cover gasket yet. Even if they changed the valve cover, how would the gasket change? It still has to bolt up to the head and those bolt holes can't change. I will have to take a closer look at them to see if the right will be able to flip around and fit on the left, I would hate to have the thing all apart without the proper gasket. Waiting to hear back from ECS because their site does list something about 2007 being a split year with this left gasket.
Meantime, looks like you do need your VIN. Two quick checks at some of my go to places for Audi's :
https://www.autohausaz.com/catalog/c...ket?s=d&page=1
https://www.rmeuropean.com/Make/Audi...bcatID=1387718
Some of the history around this looks like it may be in the parts slide I pulled off one of the std. Euro ETKA sites. ##15 and 17 below:
Thanks to MP, I found them at rmeuropean.com they had the older style gasket for the left side if you did not update your cover. I had them changed, but am still getting some oil in the plug wells so gonna take it apart again to see what the deal is. I had no luck finding the older gasket anywhere other than this site.
I believe that they change the valve cover due to warping, but unknown why it wasn't covered under a recall if it was such a big deal to even have Audi stop making the gasket for the original cover. This is what I ordered:
https://www.rmeuropean.com/Products/...36-V13260.aspx
Audi Logic
Audi 100 / A6 (C4 Platform)
07-15-2005 01:51 AM
JazzGuitarist
07-27-2003 02:22 AM
Crisqo09 T.O.
12-13-2002 08:24 PM
