VCDS scan of my good deal A8
this is the first scan of my A8
Sunday,27,January,2019,21:48:10:54500
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 18.9.1.0
Data version: 20190114 DS296.0
Ross-Tech: Home
VIN: WAUML44E96N022335 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 1E 25 28 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 67 72 76 77
VIN: WAUML44E96N022335 Mileage: 328420km-204070miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0F2787251
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E52831CB9C3A13A7F-807A
9 Faults Found
19058 - Linear Oxygen (Lambda) Sensor B1 S1 Pump Current Trim Circuit
P2626 - 004 - Open
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 322584 km
Time Indication: 0
Freeze Frame:
RPM: 1608 /min
Load: 12.9 %
Speed: 92.0 km/h
Temperature: 74.0°C
Temperature: -6.0°C
Absolute Pres.: 0.0 mbar
Voltage: 13.716 V
18613 - Performance Malfunction in Cooling System
P2181 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 325094 km
Time Indication: 0
Freeze Frame:
RPM: 1833 /min
Load: 23.5 %
Speed: 100.0 km/h
Temperature: 72.0°C
Temperature: 7.0°C
Voltage: 14.097 V
19711 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
P3255 - 001 - Regulation at Upper Limit - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 327419 km
Time Indication: 0
Freeze Frame:
RPM: 1653 /min
Load: 56.4 %
Speed: 91.0 km/h
Temperature: 74.0°C
Temperature: 15.0°C
Voltage: 14.097 V
16514 - Oxygen (Lambda) Sensor B1 S1
P0130 - 001 - Malfunction in Circuit
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 327419 km
Time Indication: 0
Freeze Frame:
RPM: 687 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 57.0°C
Temperature: 6.0°C
Voltage: 13.843 V
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Voltage: 0.000 V
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 328408 km
Time Indication: 0
Freeze Frame:
RPM: 100 /min
Load: 76.4 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 6.0°C
Voltage: 10.160 V
19713 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
P3257 - 001 - Regulation at Upper Limit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 328417 km
Time Indication: 0
Freeze Frame:
RPM: 1035 /min
Load: 18.8 %
Speed: 36.0 km/h
Temperature: 75.0°C
Temperature: -4.0°C
Voltage: 13.843 V
16534 - Oxygen (Lambda) Sensor B2 S1
P0150 - 001 - Malfunction in Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 328417 km
Time Indication: 0
Freeze Frame:
RPM: 1013 /min
Load: 18.4 %
Speed: 35.0 km/h
Temperature: 75.0°C
Temperature: -4.0°C
Voltage: 13.081 V
18683 - Oxygen (Lambda) Sensor B1 S1: Negative Lead
P2251 - 004 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 328429 km
Time Indication: 0
Freeze Frame:
RPM: 687 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 57.0°C
Temperature: 6.0°C
Voltage: 13.335 V
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0100
Revision: --H01--- Serial number: 0080211
Coding: 0000002
VCID: 25407C30EC35E2628E-8070
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 224A672CFD1B155AEB-8076
1 Fault Found
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F2787251
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BE05C4EBC78F8AC5-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 165
Mileage: 325056 km
Time Indication: 0
Date: 2018.11.02
Time: 17:50:52
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 14
Reset counter: 7
Mileage: 325056 km
Time Indication: 0
Date: 2018.11.02
Time: 20:00:30
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 326480 km
Time Indication: 0
Date: 2018.11.29
Time: 16:32:56
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 0
Reset counter: 25
Mileage: 327712 km
Time Indication: 0
Date: 2018.12.27
Time: 12:19:04
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
VCID: 24466134E70F1B6A99-8070
3 Faults Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 21
Mileage: 64348 km
Time Indication: 0
Date: 2018.11.29
Time: 16:33:00
01970 - Seat Depth Adjustment Button (E350); Backwards
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 65472 km
Time Indication: 0
Date: 2018.12.26
Time: 13:11:17
01969 - Seat Depth Adjustment Button (E350); Forward
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 65472 km
Time Indication: 0
Date: 2018.12.26
Time: 13:11:17
Address 07: Control Head Labels: Redir Fail!
Part No SW: 4E0 910 731 N HW: 4E0 035 729
Component: Interfacebox H43 3360
Revision: 00000000 Serial number: 346CO067531338
Coding: 0000003
Shop #: WSC 93362 999 84678
VCID: 2C5689148FDFD32A51-8078
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000003318
Subsystem 3 - Serial number: 0116.03.060000000100010160ÿ
Subsystem 4 - Serial number: 010160ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000091846
Coding: 0069969
VCID: 1C3659D4DF7F23AA21-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO09032006065A000000000081ÿ†89
Subsystem 5 - Serial number: 000081ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO08032006065A00000000
Subsystem 7 - Serial number: 65A000000000097ÿ
2 Faults Found
00065 - Rear Left Footwell Heater (Z42)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 145
Mileage: 301065 km
Time Indication: 0
Date: 2017.02.24
Time: 23:16:06
Freeze Frame:
Voltage: 11.30 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 145
Mileage: 301065 km
Time Indication: 0
Date: 2017.02.24
Time: 23:16:07
Freeze Frame:
Voltage: 11.30 V
Address 09: Cent. Elect. Labels: None
Part No SW: 4E0 910 279 Q HW: 4E1 955 113 B
Component: ILM Fahrer H14 0230
Coding: 0143104
VCID: 3662AB7C419399FA37-8062
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000034
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557
Component: REGENLICHTSENSORH11 0050
Coding: 00139548
Shop #: WSC 02313
2 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 327615 km
Time Indication: 0
Date: 2018.12.26
Time: 13:04:39
02746 - Bulb for Daytime Running Light; Right
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 328429 km
Time Indication: 0
Date: 2019.01.26
Time: 22:35:18
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF7271406
Shop #: WSC 00000 000 00000
1 Fault Found
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 46
Mileage: 328408 km
Time Indication: 0
Date: 2019.01.19
Time: 00:00:19
Freeze Frame:
Text: 00000000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 3630
Revision: 91H12360 Serial number: 0037Q0004WUG
Coding: 0532707
VCID: 26427B3C9133E97A87-8072
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 35Y05
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB40106AA09Eÿ†63
Subsystem 5 - Serial number: 6AA09Eÿ†63428RB40106AE4BPÿ†63
Subsystem 6 - Serial number: 6AE4BPÿ†63528RB40106AA28Hÿ†63
Subsystem 7 - Serial number: 6AA28Hÿ†63628RB40106AE20Eÿ†63
Subsystem 8 - Serial number: 6AE20Eÿ†63729RB40105A6005ÿ†63
Subsystem 9 - Serial number: 5A6005ÿ†63829RB40105A639Iÿ
Subsystem 10 - Serial number: 5A639Iÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: 65C03C30ACB522624E-8030
Component: Lenkradmodul H07 0090
1 Fault Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 46
Mileage: 326492 km
Time Indication: 0
Date: 2018.11.29
Time: 16:32:58
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 T HW: 4E0 920 900 T
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3F2007874
Coding: 0032363
Shop #: WSC 93204 999 04950
VCID: 306E9D64A3F7B7CA6D-8064
1 Fault Found
16346 - Control Module - ROM Error
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 295552 km
Time Indication: 0
Date: 2016.09.20
Time: 11:32:08
Address 19: CAN Gateway Labels: None
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 200030621980C0
Coding: FCFE7FDC3B7104
VCID: 275C76389639F072BC-8072
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 20
Mileage: 326492 km
Time Indication: 0
Date: 2018.11.29
Time: 16:32:58
Address 1E: Media Player 2 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 275C76385639F072BC-8072
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
4 Faults Found
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 165
Mileage: 325056 km
Time Indication: 0
Date: 2018.11.02
Time: 17:50:52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 7
Mileage: 325056 km
Time Indication: 0
Date: 2018.11.02
Time: 20:00:30
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 326480 km
Time Indication: 0
Date: 2018.11.29
Time: 16:32:56
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 25
Mileage: 327712 km
Time Indication: 0
Date: 2018.12.27
Time: 12:19:04
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000019 Serial number: 00000000038143
Coding: 0000001
VCID: 61C82820B89D4E42B2-8034
2 Faults Found
01850 - Temperature Sensor for Heated Seat; Rear Right (G95)
010 - Open or Short to Plus - Intermittent
01849 - Temperature Sensor for Heated Seat; Rear Left (G94)
Address 34: Level Control Labels: None
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A5A8F0C852BCD1AA3-807E
4 Faults Found
01583 - Leak in System Detected
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 108
Reset counter: 46
Mileage: 0 km
Time Indication: 0
01400 - Suspension Level Control
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 138
Reset counter: 47
Mileage: 325058 km
Time Indication: 0
Date: 2018.11.02
Time: 17:52:41
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 122
Reset counter: 43
Mileage: 325061 km
Time Indication: 0
Date: 2018.11.03
Time: 11:23:54
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 42
Mileage: 327842 km
Time Indication: 0
Date: 2018.12.31
Time: 13:49:15
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071658
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 21
Mileage: 64348 km
Time Indication: 0
Date: 2018.11.29
Time: 16:33:00
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 D
Component: MNS US H48 0990
Revision: 00000000 Serial number: 381IY067506089
Shop #: WSC 93078 999 53901
VCID: 31689860A8FDBEC262-8064
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H03 0090
Serial number: 00000604200018
Coding: 0003477
VCID: 1D3054D0C4652AA2D6-8048
1 Fault Found
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 20
Mileage: 262136 km
Time Indication: 0
Date: 2018.11.29
Time: 16:32:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
VCID: 204E6D24F317074AFD-8074
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040603070132
Coding: 0048702
VCID: 285E75049B27FF0AB5-807C
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
4 Faults Found
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 7
Mileage: 284701 km
Time Indication: 0
Date: 2016.02.12
Time: 22:48:02
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 20
Mileage: 327615 km
Time Indication: 0
Date: 2018.12.26
Time: 13:04:36
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 38
Mileage: 328066 km
Time Indication: 0
Date: 2019.01.04
Time: 17:19:04
01828 - Bulb for Tail-Lamp; Left
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 37
Mileage: 328167 km
Time Indication: 0
Date: 2019.01.16
Time: 15:52:04
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000007365
Coding: 0000016
1 Fault Found
01044 - Control Module Incorrectly Coded
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 47
Mileage: 328211 km
Time Indication: 0
Date: 2019.01.17
Time: 08:49:14
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000080642
Coding: 0010111
VCID: 1E3253DCC96331BACF-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T13W805
2 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 21
Mileage: 0 km
Time Indication: 0
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Status: 01110100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 7
Mileage: 262136 km
Time Indication: 0
Date: 2018.11.02
Time: 17:02:00
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake Labels: None
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
VCID: 1F4C6ED8CE6938B2C4-804A
5 Faults Found
01439 - Check Inclination
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 4
Fault Frequency: 52
Reset counter: 7
Mileage: 328408 km
Time Indication: 0
Date: 2019.01.19
Time: 00:27:43
Freeze Frame:
Voltage: 10.46 V
Count: 101
02433 - Supply Voltage for Right Parking Brake Motor (V283)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11111100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 231
Mileage: 327448 km
Time Indication: 0
Date: 2018.12.24
Time: 15:44:22
Freeze Frame:
Voltage: 13.87 V
Count: 57
011 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11111011
Fault Priority: 2
Reset counter: 181
Mileage: 319536 km
Time Indication: 0
Date: 2018.07.20
Time: 11:09:00
Freeze Frame:
Voltage: 13.15 V
Count: 93
02440 - Function Display in Instrument Cluster (P)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 6
Reset counter: 7
Mileage: 319448 km
Time Indication: 0
Date: 2018.07.19
Time: 10:24:44
Freeze Frame:
Voltage: 12.63 V
Count: 62
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 227
Time Indication: 0
Freeze Frame:
Voltage: 9.83 V
Count: 61
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 388G%067538375
Coding: 0000002
Shop #: WSC 31414 790 00001
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: ENERGIEMANAGER H11 0390
Revision: 00000000 Serial number: 00000000000016
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 2505170164
Coding: 303030393135313035414B56413032353035313730313634
Shop #: WSC 23436 444 73072
2 Faults Found
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 328408 km
Time Indication: 0
Date: 2019.01.19
Time: 17:25:22
00992 - Consumption Cut-Off Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 328408 km
Time Indication: 0
Date: 2019.01.19
Time: 00:27:58
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000605230127
Shop #: WSC 12336 024 394758
VCID: 3466917457EF8BEA09-8060
2 Faults Found
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Status: 00110100
Fault Priority: 5
Fault Frequency: 31
Reset counter: 46
Mileage: 325064 km
Time Indication: 0
Date: 2018.11.04
Time: 12:50:28
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 139
Reset counter: 7
Mileage: 325058 km
Time Indication: 0
Date: 2018.11.02
Time: 17:01:39
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
1 Fault Found
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 0
Reset counter: 40
Mileage: 328208 km
Time Indication: 0
Date: 2019.01.16
Time: 22:25:06
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720627202091
Coding: 0221208
VCID: 23446228E2011C52E0-8076
1 Fault Found
02070 - Rear Parking Aid Sensors
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 165
Mileage: 325058 km
Time Indication: 0
Date: 2018.11.02
Time: 17:50:39
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 D HW: 4E0 862 335
Component: Handyvorb2 H11 0700
Revision: 00000000 Serial number: 00000007535078
Coding: 0010900
End-------------------------(Elapsed Time: 03:00)--------------------------
Ross-Tech: Home
Coding: 0007773
9 Faults Found
P2626 - 004 - Open
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 322584 km
Time Indication: 0
Freeze Frame:
RPM: 1608 /min
Load: 12.9 %
Speed: 92.0 km/h
Temperature: 74.0°C
Temperature: -6.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 325094 km
Time Indication: 0
Freeze Frame:
RPM: 1833 /min
Load: 23.5 %
Speed: 100.0 km/h
Temperature: 72.0°C
Temperature: 7.0°C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 327419 km
Time Indication: 0
Freeze Frame:
RPM: 1653 /min
Load: 56.4 %
Speed: 91.0 km/h
Temperature: 74.0°C
Temperature: 15.0°C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 327419 km
Time Indication: 0
Freeze Frame:
RPM: 687 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 57.0°C
Temperature: 6.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 328408 km
Time Indication: 0
Freeze Frame:
RPM: 100 /min
Load: 76.4 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 6.0°C
Voltage: 10.160 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 328417 km
Time Indication: 0
Freeze Frame:
RPM: 1035 /min
Load: 18.8 %
Speed: 36.0 km/h
Temperature: 75.0°C
Temperature: -4.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 328417 km
Time Indication: 0
Freeze Frame:
RPM: 1013 /min
Load: 18.4 %
Speed: 35.0 km/h
Temperature: 75.0°C
Temperature: -4.0°C
Voltage: 13.081 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 328429 km
Time Indication: 0
Freeze Frame:
RPM: 687 /min
Load: 22.3 %
Speed: 0.0 km/h
Temperature: 57.0°C
Temperature: 6.0°C
Voltage: 13.335 V
Coding: 0000002
Coding: 0007597
1 Fault Found
Coding: 0410624
Component: ELV XXXX
4 Faults Found
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 165
Mileage: 325056 km
Time Indication: 0
Date: 2018.11.02
Time: 17:50:52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 7
Mileage: 325056 km
Time Indication: 0
Date: 2018.11.02
Time: 20:00:30
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 326480 km
Time Indication: 0
Date: 2018.11.29
Time: 16:32:56
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 25
Mileage: 327712 km
Time Indication: 0
Date: 2018.12.27
Time: 12:19:04
Coding: 4071648
3 Faults Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 21
Mileage: 64348 km
Time Indication: 0
Date: 2018.11.29
Time: 16:33:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 65472 km
Time Indication: 0
Date: 2018.12.26
Time: 13:11:17
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 65472 km
Time Indication: 0
Date: 2018.12.26
Time: 13:11:17
Coding: 0000003
Coding: 0069969
2 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 145
Mileage: 301065 km
Time Indication: 0
Date: 2017.02.24
Time: 23:16:06
Freeze Frame:
Voltage: 11.30 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 145
Mileage: 301065 km
Time Indication: 0
Date: 2017.02.24
Time: 23:16:07
Freeze Frame:
Voltage: 11.30 V
Coding: 0143104
Coding: 00000034
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
2 Faults Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
Mileage: 327615 km
Time Indication: 0
Date: 2018.12.26
Time: 13:04:39
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 328429 km
Time Indication: 0
Date: 2019.01.26
Time: 22:35:18
1 Fault Found
02261 - Data Medium
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 46
Mileage: 328408 km
Time Indication: 0
Date: 2019.01.19
Time: 00:00:19
Freeze Frame:
Text: 00000000
Coding: 0532707
Coding: 0012141
1 Fault Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 46
Mileage: 326492 km
Time Indication: 0
Date: 2018.11.29
Time: 16:32:58
Coding: 0032363
1 Fault Found
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 295552 km
Time Indication: 0
Date: 2016.09.20
Time: 11:32:08
1 Fault Found
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 20
Mileage: 326492 km
Time Indication: 0
Date: 2018.11.29
Time: 16:32:58
Revision: 00000000
Coding: 0410624
Component: ELV XXXX
4 Faults Found
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 165
Mileage: 325056 km
Time Indication: 0
Date: 2018.11.02
Time: 17:50:52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 7
Mileage: 325056 km
Time Indication: 0
Date: 2018.11.02
Time: 20:00:30
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 326480 km
Time Indication: 0
Date: 2018.11.29
Time: 16:32:56
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 25
Mileage: 327712 km
Time Indication: 0
Date: 2018.12.27
Time: 12:19:04
Coding: 0000001
2 Faults Found
Coding: 0015510
4 Faults Found
Freeze Frame:
Fault Priority: 3
Reset counter: 46
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Reset counter: 47
Mileage: 325058 km
Time Indication: 0
Date: 2018.11.02
Time: 17:52:41
Freeze Frame:
Fault Priority: 3
Reset counter: 43
Mileage: 325061 km
Time Indication: 0
Date: 2018.11.03
Time: 11:23:54
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 42
Mileage: 327842 km
Time Indication: 0
Date: 2018.12.31
Time: 13:49:15
Coding: 4071658
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 21
Mileage: 64348 km
Time Indication: 0
Date: 2018.11.29
Time: 16:33:00
Coding: 0003477
1 Fault Found
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 20
Mileage: 262136 km
Time Indication: 0
Date: 2018.11.29
Time: 16:32:00
Coding: 0032364
Coding: 0048702
4 Faults Found
Freeze Frame:
Fault Priority: 3
Reset counter: 7
Mileage: 284701 km
Time Indication: 0
Date: 2016.02.12
Time: 22:48:02
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 20
Mileage: 327615 km
Time Indication: 0
Date: 2018.12.26
Time: 13:04:36
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 38
Mileage: 328066 km
Time Indication: 0
Date: 2019.01.04
Time: 17:19:04
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 37
Mileage: 328167 km
Time Indication: 0
Date: 2019.01.16
Time: 15:52:04
Coding: 0000016
1 Fault Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 47
Mileage: 328211 km
Time Indication: 0
Date: 2019.01.17
Time: 08:49:14
Coding: 0010111
2 Faults Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 21
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 7
Mileage: 262136 km
Time Indication: 0
Date: 2018.11.02
Time: 17:02:00
Cannot be reached
Revision: A32C0220
Coding: 0000532
5 Faults Found
Freeze Frame:
Fault Priority: 4
Fault Frequency: 52
Reset counter: 7
Mileage: 328408 km
Time Indication: 0
Date: 2019.01.19
Time: 00:27:43
Freeze Frame:
Voltage: 10.46 V
Count: 101
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 231
Mileage: 327448 km
Time Indication: 0
Date: 2018.12.24
Time: 15:44:22
Freeze Frame:
Voltage: 13.87 V
Count: 57
Freeze Frame:
Fault Priority: 2
Reset counter: 181
Mileage: 319536 km
Time Indication: 0
Date: 2018.07.20
Time: 11:09:00
Freeze Frame:
Voltage: 13.15 V
Count: 93
Freeze Frame:
Fault Priority: 6
Reset counter: 7
Mileage: 319448 km
Time Indication: 0
Date: 2018.07.19
Time: 10:24:44
Freeze Frame:
Voltage: 12.63 V
Count: 62
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 227
Time Indication: 0
Freeze Frame:
Voltage: 9.83 V
Count: 61
Coding: 0000018
Coding: 0000002
2 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 328408 km
Time Indication: 0
Date: 2019.01.19
Time: 17:25:22
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 328408 km
Time Indication: 0
Date: 2019.01.19
Time: 00:27:58
Coding: 0032364
2 Faults Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 31
Reset counter: 46
Mileage: 325064 km
Time Indication: 0
Date: 2018.11.04
Time: 12:50:28
000 - -
Freeze Frame:
Fault Priority: 5
Reset counter: 7
Mileage: 325058 km
Time Indication: 0
Date: 2018.11.02
Time: 17:01:39
Coding: 0032364
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 40
Mileage: 328208 km
Time Indication: 0
Date: 2019.01.16
Time: 22:25:06
Coding: 0221208
1 Fault Found
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 165
Mileage: 325058 km
Time Indication: 0
Date: 2018.11.02
Time: 17:50:39
Coding: 0010900
I did disconnect the battery (which I think is too big) to try and fit it in better
maybe thats where some of these codes came from
(I clear and see what comes back)
or maybe its just a basket case of a car
Awesome scan. I don't read them unless I'm troubleshooting one of my own vehicles.
As has been suggested many times here, clear the faults in each module individually and then see what reappears. Repair each fault individually using the guided fault-finding steps in the service manual as well as using standard automotive troubleshooting techniques.
My son's GF just bought a 2004 A8 for the cost of one strut. So far they are up to double that in parts. Thank goodness for her he does not charge her for labor. Just had both pinch bolts in front snap off trying to remove the upper control arms. Two used steering knuckles/bearing housings on the way from a recycler in Minnesota for $120.00 each.....
The parts on a German car do not go down in price as they get older.....
+1 I don't even read on mine LOL. Clear everything and scan again, I would run if they have all those problems. Just drive the car, check everything if they work, if it feels right, buy it. The first instinct is always right.
Good deal is relative... Really. Cheap car doesn't mean a good deal.
Looking For The Best Used A8 D3 ? Audi
Cheers and good luck,
Louis
Louis
A
Basenco
14
02-21-2018 02:57 AM
kamrooz
10-30-2017 07:13 PM
cyrus89
29
03-24-2015 12:34 PM
