W12 executive rear seat removal
Does anyone know the removal procedure for the rear seat on a 2006 W12 A8L executive bucket seats ? |
thats the best kept secret in the US
Originally Posted by Ceedubbu
(Post 25290547)
Does anyone know the removal procedure for the rear seat on a 2006 W12 A8L executive bucket seats ? Let me know if you find out how to do any of those procedures. Are you in the US ? |
I’m in Canada Eh. I asked my local Audi dealer who loves me and my repair bills but they had no idea supposedly. I need to access an Harness plug that is causing a light on the dash. The only way is to remove the seat. If I figure it out I’ll let you know . |
It is documented in the Bentley manual IIRC. It has been literally 10+ years since I did it so I don't remember specifics beyond that I followed the manual. The seats were not particularly hard as I recall. You have to disconnect the airbags before removing in full.
Removing and installing centre sectiont Removing– Pull the centre section -1- upwards in arrow direction and out in the direction of travel.t Installing– Install the centre section -1- in the reverse order of removal.
Removing and installing seat pan=right1 - Individual rear seat =right2 - Seat pan t Removing – Move the seat angle adjuster to the top position and the longitudinal adjuster to the centre position. – Reach beneath the seat on the sill panel side and feel for the lever -3-. – Press the lever -3- and pull the seat pan -2- upwards. – Unplug the connector beneath the seat pan -2-. – Disengage the seat pan -2- in the direction of travel from the individual rear seat -1-. t Installing – Engage the seat pan -2- on the left and right in the individual rear seat -1- → Fig. – Press down the seat pan -2- until it engages at the front. =right3 - Lever https://cimg4.ibsrv.net/gimg/www.aud...3777bd6e68.png
Rear seat pan attachment[img]file:///C:\Users\Corey\AppData\Local\Temp\msohtmlclip1\01\ clip_image001.gif[/img] NoteThe guide -1- (2x) must always be replaced following removal. On installation, the seat pan must engage at the rear in the guide -1- on the left and right.
https://cimg7.ibsrv.net/gimg/www.aud...8e1d388ab8.png |
Removing and installing individual rear seat
https://cimg7.ibsrv.net/gimg/www.aud...f771ea8d51.png=right1 - Bolt q Tightening torque 55 Nm =right2 - Tab =right3 - Individual rear seat t Removing – Remove the seat pan → Chapter. – Unplug the connectors -7-, -8-, -9- and -10-. – Detach the wiring harness -13- from the body. – Raise the tab -11- and unscrew the bolt -12-. – Raise the tab -14- and unscrew the bolt -15-. – Pull the tab -2- aside and unscrew the bolt -1-. – Open the webbing guide -5- at the clip -6-. – Thread the webbing -4- out of the guide -5-. – Unscrew the bolt at the anchorage point of the webbing -4- → Chapter.– Pull the seat frame forwards until the backrest slides out of its guide. – Lift the individual rear seat -3- out of the vehicle. t Installing – Install the individual rear seat -3- in the reverse order of removal. – Make sure the individual rear seat -3- engages on the left and right at the sliders in the guides in the body. =right4 - Webbing =right5 - Webbing guide =right6 - Clip =right7 - Connector =right8 - Connector =right9 - Connector =right10 - Connector =right11 - Tab =right12 - Bolt q Tightening torque 55 Nm =right13 - Wiring harness =right14 - Tab =right15 - Bolt q Tightening torque 55 Nm =right16 - Tab =right17 - Bolt |
Removing and installing backrest holder – Remove the seat pan → Chapter. – Remove the backrest → Chapter. – Unscrew the nuts -2- (4x). Tightening torque 8 Nm – Detach the backrest holder -1-. =right3 - Felt padhttps://cimg4.ibsrv.net/gimg/www.aud...d849d53bf6.png
