Sponsored by:
Sponsored by:
Xenon bulb replaced, still doesn't work
Old 02-19-2018, 12:12 PM
krazzz's Avatar
Default Xenon bulb replaced, still doesn't work
My driver's side low beam headlight has been working intermittently for the past year. It started to fail only occasionally and now 9 times out of 10 it isn't working. I replaced the bulb and it still isn't working. From what I can tell there are two other parts, the ballast and the control module. Is there a way to test them? If not, which of them is more likely to fail? How about a ground issue? Does anyone know where the ground is located for the driver's headlight? Thanks!
Old 02-20-2018, 10:29 AM
benmag's Avatar
switch the ballast with the odder side, then you will se if it work or not
Old 02-20-2018, 01:38 PM
jlbell's Avatar
Check out my old post:
https://www.audiworld.com/forums/a8-...issue-2915169/
SixStick
Audi allroad
05-26-2018 07:45 AM
Steve in Calif
07-26-2017 02:29 AM
hzraudi6
08-19-2012 03:36 PM
jzkbbi
04-05-2011 07:15 PM
Gettysburg
08-30-2006 11:14 AM
Quick Reply: Xenon bulb replaced, still doesn't work
