2012 3.0tdi power steering problem
Hi, I have started to have intermittent problem with the power steering cutting out, normally at low speed and with little/no throttle. It has been scanned and no fault codes and also no hydrolic leaks and the fluid is at the correct level. Could a faulty battery cause this? The reason I ask is that it had a new alternator a few months ago and although I have not had any warnings or problems starting I have noticed that the stop/start isn't working either? Many thanks
Power steering pumps are known to die on 3.0 TDI. I had to change mine in my Q7 TDI. It was just faulty. I bought mine from europaparts for like $300. When it comes to stop/start I would say check FOB battery. If FOB battery is new get someone with Ross tech and make sure your comfort setting is enabled for start/stop. Also, car battery needs to be programmed into the car for proper operation.
I would scan it with VCDS and see what is going on with that system. Was the battery properly installed in the car? Battery Replacement - Ross-Tech Wiki
if the battery is 6 years old replace it.
Chris Brookes
02-15-2019 08:35 AM
BoostFrenzy
01-27-2003 06:07 PM
