2013 Audi A8L D4 Door Panel Removal Help
Is there anyone knows how to remove the Front Door
Panel D4 Left and Right for Audi 2013 A8L. I need to replace the woofers. I have attached some photos of the Left and Right panel doors. I was able to remove the screws located on the wood trims but still unable to detach the panels. https://cimg8.ibsrv.net/gimg/www.aud...0d8e39214.jpeg Front Left wood trim removed https://cimg3.ibsrv.net/gimg/www.aud...7a13b91b4.jpeg Front Right wood trim removed https://cimg4.ibsrv.net/gimg/www.aud...b16e8e868.jpeg Front Left https://cimg5.ibsrv.net/gimg/www.aud...e30fae535.jpeg Front Right Any photos you can share will be helpful. I appreciate the help! |
You are on the right path.
Behind the wood trim. Behind the small speaker grill below the door handle. You see the switch, below it, look from down to up. there are no screws next to the big speaker. everything else are plastic rivets why do you want to replace the speakers? And with what? |
Thanks for the info. The two woofers are both
blown out. |
blown out. Im replacing it with exactly the same Bose woofers. |
Did you grab any pics of the door with the card removed?
