2013 S8 questions regarding brakes and something else
#11
Okay after taking a little more time I definitely am going to upgrade both sets of rotors now that I am at 55k miles. I really want either slotted or drilled but having a tough time finding front rotors like this though I know they are available. Any help here?
I upgraded rear pads to EBC Red stuff and will be doing same on front pads.
#12
Net, cheapest practical source will be a discounted/on line dealer. Brakeworld might be cheaper than adams rotors, and as noted I think both probably start with stock so their are yet more mark ups. If stock, try to find a dealer currently doing free shipping, since rotors are $$ to ship. audiusaparts was, but seems to have dropped it again in recent weeks. Comes up as a promotion with them from time to time though, and others may be doing it now/still.
#14
In Europe you can now (since maybe 6-9 mth's) get Zimmerman rotors which seem identical to OE. I got a set and it works fine however not sure there is money to be saved on getting these, mine were around $240 each.
#15
2) I have encountered a very strange noise that will be somewhat hard to explain but I will try. When reversing out of a parking space and then cutting the wheel all the way I sometimes get a fairly loud noise that sounds almost like I ran over an aluminum can or ran over a chunk of snow or something, it is somewhat of a thump but can easily be heard. Sometimes passengers will ask what I just ran over. It doesn't always do it but probably 33-50% of the time. When I go over speed bumps the front suspension almost sounds like old coil suspension with a sort of squeal but usually only when I hit a speed bump somewhat fast. The rear sounds normal. Any idea as to what could be wrong to cause this?[/QUOTE]
I had the same "clunk" over speed bumps as well, took it to the dealer, they swapped out all the sway bar bushings before they figured it out that both struts were shot, that was at 40k miles. Took then awhile to fiugre it out
#16
Hey guys, so I got a quote for the following on brakes but I need to know if it is a good deal and also whether I need a couple of these line items. My dad works out Audi so of course the rotors are a good price but wasn't aware I needed the other items, thoughts?:
Brk Lining: $207.35 x 1
Wire: $48.84 x 2
Springs: $62.70 x 2
Front rotors: $236 x 2
Rear rotors: $168 x 2
Wire: $48.84 x 2
Springs: $62.70 x 2
#17
Wire: $48.84 x 2
Springs: $62.70 x 2
Wire: $48.84 x 2
Springs: $62.70 x 2
- brake lining--that means pads, but likely that is just one set included, probably fronts. You need rears too if getting rear rotors.
- wire--likely that means the wear sensors. I don't recall on D4 if both sides have them; lesser Audis are only on one side. On D4 they are front and rear. If brake wear light is on, definitely one needs changing. Sometimes folks can reuse non-worn through ones. Other times they break on removal. Audi ones are way pricy compared to aftermarket, like 6-10x. Also covered in a prior reply of mine below.
- springs--probably a pad retainer spring in front, but I dont recall D4 set up is like this. Other Brembos use pins to hold pads in, and the spring then retains those pins. You need to look at a parts diagram for that level of detail. Most indies, and I, would probably just reuse this type of pad related metal hardware unless really trashed and old. Rears usually have an antirattle related set of stainless clips too, which likewise are usually just cleaned and reused.
- rotors--obvious.
- Front pad damper washer set--they go on each piston of front calipers--12 total sold as a set. Pricy, at $200 range. Some reuse by peeling carefully off old pads and then applying to new ones. Dealer replaces.
- Audi says replace all main caliper bolts that hold them to the hub area, which I normally do these days. Many indies probably don't. Not particularly expensive, especially compared to something like those damper washers.
- Little torx screws that hold each rotor to hub during assembly. Less than $1 each.Qty. 4 total. Commonly freeze up or strip on older ones and then end up drilled out, so good idea to replace after some years during a rotor change.
#18
I just had the rear brakes done on my 2015 A8 (NWB) 4.0T. Dealer had noted at last service that rear pads were nearly worn to the sensor and gave me a quote for $1200 for rear pads, rotors and sensors. I took it to a local indy shop who did the same for about $650. Only (minor) issue was determining rotor size - the search by VIN yielded 3 different options, and the local Audi parts wholesaler wasn't sure either when the shop called to order the parts. I called the dealer parts desk and was told that 356mm was the right size, which turned out to be correct.
