Sponsored by:
Sponsored by:
ACC, braking guard, and lane assist unavailable
Old 06-22-2019, 05:16 PM
Moderator
virtualrc's Avatar
Default ACC, braking guard, and lane assist unavailable
This week I received warnings that the ACC, breaking guard, and lane assist were unavailable. After reviewing VCDS logs I've zeroed in on the following issues:
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4H0 907 561 C HW: 4H0 907 561
Component: ACC3 H21 0032
Serial number: 00000000000000
Coding: 7E01020101
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AdaptCruisContrAU64X 002024
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2B030519E389131F4F7-807E
1 Fault Found:
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_VIDEO_FAIL]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 204
Mileage: 124931 km
Date: 2019.06.18
Time: 18:12:52
Control Module temperature: 52 �C
Voltage terminal 15: 13.958 V
Velocity_vehicle_reference: 7.83 m/s
Longitudinal_acceleration_vehicle_reference: -2.10 m/s�
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4H0 907 107 G HW: 4H0 907 107
Component: BV-SG H32 0084
Serial number: 005000480906147
Coding: 02C19A000111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
1 Fault Found:
0080 - Video Cable for Image Processing
C1107 02 [008] - Signal Failure
[No_connection_to_camera]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 204
Mileage: 124931 km
Date: 2019.06.18
Time: 18:12:51
Outside air temperature: 35.0 �C
Voltage terminal 15: 14.2 V
Control Module temperature: 47.0 �C
Codes were cleared but the issues persist. On two occasions since the initial issue ACC, lane assist, and presumably braking guard came back to life but on next drive cycle the issues came back. Doing some research I started to look into the camera and imaging processing system components. So far I've accessed the windshield camera and removed and reseated the cables. My next step is to do the same on the image processing unit under the passenger seat. If simple removal and reseating don't fix this I'm hoping someone here has more ideas to try. Would an Audi dealer or indy shop have a way to test these components more thoroughly than a scan? Is one part of the system (camera or processing unit) more likely to fail than the other? If I source my own parts would that be a simple swap out or is special programming or adaptation required?
Old 06-22-2019, 05:39 PM
Tuesday's Avatar
You're not alone. My 2015 3.0 A8L does this every time the temperatures reach and sustain over 95 degrees. I thought it was an ACC sensor issue - and I pulled the same codes as you in VCDS. What really makes me believe it is a camera/imagine issue is that when I try to turn on lane assist after the error pops up it tells me something about no vision from the camera. I took the camera out, like you, and reseated the cables - I even used a q-tip dipped in windex to clean the inside of the windshield behind the camera mount thinking perhaps that would help - and it hasn't. I look forward to seeing what progress you are able to make. I really never use those features but it would be nice to have them.
CommishinNC (11-02-2020)
Old 06-22-2019, 06:08 PM
Moderator
virtualrc's Avatar
I find it interesting that you mention the temperature. I almost thought of mentioning that one potential change in context for this issue was that things are starting to heat up here in N. Texas. This will be my first summer with the car (bought back in Nov. 2018) so I am curious as to what to expect in warmer temperatures.
Something I did find on the Ross Tech forums is a user who claims that a swap out of the cable fixed their issue. That seems like a real pain in the *** to swap out. Said they trimmed some plastic off the connector ends to create a better connection as their test.
https://forums.ross-tech.com/showthr...l=1#post138552
Has anyone here tried or heard of this fix?
jobbie (10-04-2023)
Old 06-22-2019, 07:55 PM
viggense's Avatar
I have had a 2012 A7, 2016 A7, and currently have a 2014 A8L, all of which have had the driver assistance package. During the summer when the car sat in the sun while I was working, I would get all of the driver assist faults when I started it up. However, if I drove it for a while with the A/C on and restarted the car after going to the store, etc. the faults were gone.
Old 06-24-2019, 06:13 AM
Cuba's Avatar
I see this thread isn't too old... I'm having the issue in a 2013 A6. It seems like a loose connection since it comes on right away sometimes, and sometimes after driving several miles. Annoying since I'm starting to get the itch to trade in the car which is otherwise in great shape. I have a good indy shop I need to take it to anyway so hopefully they can track it down for a reasonable price, I will let you know what I find.
jobbie (06-28-2023)
Old 06-24-2019, 09:34 AM
2001 S8's Avatar
That would be great Cuba. On my back from picking my car up in Chicago, I had the same issue/error happen twice. Since the car was "new to me", I didn't know if I did something to trigger it. Thanks for digging in to this, Cuba.
I will note, it wasn't overly hot that day. Maybe around 75 degrees Fahrenheit with partial sun.
Old 06-24-2019, 05:12 PM
Jibsymalone's Avatar
Just my $0.02, I live in Florida and as such see pretty high temps (car was reporting 107 today when I set off from work) but I haven't had a single issue (touch wood) with this as of yet, maybe (hopefully) I got lucky and got a Wednesday car! 😂😂
Old 06-24-2019, 05:20 PM
Moderator
virtualrc's Avatar
Hey Jibsymalone, what model year is your vehicle? Wondering if there was an engineering fix after MY 2015. Maybe they updated the cable between camera and processing unit.
Old 06-24-2019, 05:23 PM
Mine is a 2014 (US version) TDI A8L, sorry, should have mentioned that...
Old 07-01-2019, 11:34 AM
Cuba's Avatar
Slight update, the shop just called and it passed inspection fine but they said they pulled a few codes related to this ACC fault. He said he's not sure yet and was asking how I want to proceed with diagnosing it. Apparently the camera unit is not talking to the computer. Maybe a loose connection, maybe the camera is dead/dying, but it will cost me $140/hr to find out. Anyone know what one of those cameras go for these days??
WISH ME LUCK... I'll be bringing it back in next week sometime to have them track it down.
The following 2 users liked this post by Cuba:
CommishinNC (11-02-2020), virtualrc (07-02-2019)
Quick Reply: ACC, braking guard, and lane assist unavailable
