Anyone with 22" Wheels on their A8?
#91
Yes, Navin ride comfort will suffer as the sidewalls have less flex. Also consider an increased chance of wheel damage due to striking a curb or pothole at speed.
Performace will change as the final drive ratio changes due to the larger wheels. Higher top speed and slower 0-60 time. Though this may go unnoticed. Remember to recalibrate the speedometer.
Afinepoint
Afinepoint
Le diamètre de la nouvelle monte est théoriquement conforme à l'originale. Il faut encore vérifier l'indice de charge et de vitesse et si le constructeur a homologué cette monte pour votre véhicule.
#92
You are correct. If overall diameter doesn’t change then neither will my references regarding final drive ratio. Sorry I didn’t shift gears from the truck forum discussions where the guys lift the truck to put bigger wheels on to add larger tires.
cwebb818 (08-23-2019)
#97
