Audi A8 4.2L D4: Help with Steering Angle Sensor Reset
Hello Audiworld!
Recently I replaced the front suspension (except for the air shocks) on my A8 4.2L 2012.
Everything went well, just had to re-align the steering.
When I got home, I used VCDS to check for errors, and surely the Audi didn't like the geometry change.
Cleared all errors everything was fine.
So, I kept reading and found the steering angle sensor calibration screen on VCDS, and I swear it was by mistake I clicked on "next" and the thing recalibrated.
I immediately got a MIL error on the dashboard (a yellow steering wheel).
I've tried all the steering angle sensor reset procedures. Recalibration, full right lock, full left lock, drive under 20kph for more than 500 m. Everything.
Reset using vcds all the errors. But the steering MIL will not go away.
What else can I try?
The MIL error causes the ESP and Air Suspension to have error messages as well.
Please help!
I had an "active steering error", see below, but that was cleared after I cleared all errors. but the MIL steering remains as well as ESP and active suspension. See errors below.
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4H0 907 144 A HW: 4H0 907 144 A
Component: DYNAMIKLENK. H06 0080
Revision: 51001005 Serial number: --------------
Coding: 8B0000
Shop #: WSC 02311 785 00200
VCID: 2616FC1EB8E6C2D7775-8072
3 Faults Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 2
Fault Frequency: 3
Reset counter: 220
Mileage: 31997 km
Time Indication: 0
Date: 2017.06.30
Time: 18:15:49
Freeze Frame:
Count: 40
Count: 1
Hex Value: 0x05CD
Hex Value: 0x05D0
Hex Value: 0x1399
Hex Value: 0x8A00
01087 - Basic Setting Not Performed
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 31997 km
Time Indication: 0
Date: 2017.06.30
Time: 18:15:49
Freeze Frame:
Count: 56
Count: 1
Hex Value: 0x0089
Hex Value: 0x8C08
Hex Value: 0x0000
Hex Value: 0x3704
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 220
Mileage: 31997 km
Time Indication: 0
Date: 2017.06.30
Time: 18:15:50
Freeze Frame:
Count: 47
Count: 52
Hex Value: 0x0289
Hex Value: 0x8C0B
Hex Value: 0x0000
Hex Value: 0x4C00
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008004
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_VW51.rod
VCID: 2C020E36A68AF887A11-8078
2 Faults Found:
0085 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Date: 2000.00.00
Time: 00:00:00
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Date: 2000.00.00
Time: 00:00:00
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 B HW: 4H0 907 379 B
Component: ESP PREMIUM H10 0273
Revision: -------- Serial number: --------------
Coding: 44F6A200226F4500E300
ASAM Dataset: EV_ESPPremi 005006
ROD: EV_ESPPremi_005_AU64.rod
VCID: 313C1F4281A8956F927-8064
2 Faults Found:
0188 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Mileage: 31998 km
Date: 2017.06.30
Time: 18:34:24
VzRef: 00
Bit Info 1: C0
Bit Info 2: 07
Bit Info 3: A2
Bit Info 4: 00
F-Path: 2C
F-Type: 33
Uz: 95
0194 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 31997 km
Date: 2017.06.30
Time: 18:15:50
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: A2
Bit Info 4: 00
F-Path: 2B
F-Type: 16
Uz: AF
Please help!
Coding: 8B0000
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 220
Mileage: 31997 km
Time Indication: 0
Date: 2017.06.30
Time: 18:15:49
Freeze Frame:
Count: 40
Count: 1
Hex Value: 0x05CD
Hex Value: 0x05D0
Hex Value: 0x1399
Hex Value: 0x8A00
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 31997 km
Time Indication: 0
Date: 2017.06.30
Time: 18:15:49
Freeze Frame:
Count: 56
Count: 1
Hex Value: 0x0089
Hex Value: 0x8C08
Hex Value: 0x0000
Hex Value: 0x3704
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 220
Mileage: 31997 km
Time Indication: 0
Date: 2017.06.30
Time: 18:15:50
Freeze Frame:
Count: 47
Count: 52
Hex Value: 0x0289
Hex Value: 0x8C0B
Hex Value: 0x0000
Hex Value: 0x4C00
Coding: 008004
2 Faults Found:
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Date: 2000.00.00
Time: 00:00:00
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Date: 2000.00.00
Time: 00:00:00
2 Faults Found:
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Mileage: 31998 km
Date: 2017.06.30
Time: 18:34:24
VzRef: 00
Bit Info 1: C0
Bit Info 2: 07
Bit Info 3: A2
Bit Info 4: 00
F-Path: 2C
F-Type: 33
Uz: 95
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 31997 km
Date: 2017.06.30
Time: 18:15:50
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: A2
Bit Info 4: 00
F-Path: 2B
F-Type: 16
Uz: AF
I spend most of the afternoon yesterday working on this problem. No answers anywhere.
I tried to remove any other errors related to the CAN gateway. I finally was left with only the Steering "no basic setting" MIL indicator error, and the subsequent errors caused by it.
I performed all the calibration procedures on "17 - Steering Wheel" on the Ross site.
It also called to do the basic settings on "1B - Active Steering".
To no avail. The error remained. The steering was stiff, the suspension was hard and bouncy and no stability control.
Went to refuel the car and took a longish detour on rougher pavement, and came back home.
Took a beer breather and came back to it.
Got into the "34 - Level Control" module and reset the errors and voila, all MIL errors and everything was else was gone. No more errors.
I don't know if resetting the "Level Control" errors directly did it.
I doubt it, as I reset all errors too many times to remember.
Perhaps it was due to performing the 17-Steering and 1B-Active steering calibrations and then taking a test ride.
When I turned the car back on, I wasn't expecting anything (as I tried the 17-Steering calibration, but not the 1B-Active Steering basic setting), so I didn't really check if the errors were gone.
Anyway, I got my car back, and I couldn't be happier.
After the parts replace, I aligned the car again. It stays true in a straight line, but you can see the steering moving about a centimeter back and forth. It's unnerving. Like it's not settled.
I think the camber on one wheel needs attention.
I read somewhere that the camber is adjusted by shifting the subframe. I'm going to read and then take it for alignment again.
Thanks
Thanks
mrmann (10-28-2020)
Thanks
Thanks
Did find the solution for this problem I have the same issue
Regards
Makki
SAS, ESP, ACC, sport differential, etc
I'm having the same problem. Tried disconnecting the batt overnight to no avail. Tries resetting per scanner directions to no avail.....what can be done? Im getting code U111300 and U111200. I clear them to no avail.. Thanks
You need to recalibrate two modules: the steering control module and the active steering control module. They calibration is the same for both.
Set the steering angler per the instructions, and then you have to drive and completely turn to the left, advance 300 meters, and then completely turn to the right, advance 300 meters.
Let me know
Ok. Just did what you suggested. Nothing changed except steering fluid got too hot and spewed from the resivoir and now I'm dizzy from spinning...lol... I tried it twice.
JaL3 (11-10-2020)
paddymonkey
VAG-COM Discussion
06-29-2019 01:49 PM
