Audi A8 Seat as a Chair
#21
which one I need to jump together to get the side panel of buttons to adjust all the motors from the seat?
I found the phase and the neutral in the RED PLUG, but can´t get the phase to power up the side panel
#22
#23
Finally I´ve found the wiring diagram for the A8 Seat, here is:
And here is the complete PDF with all the wiring information:
TinyUpload.com - best file hosting solution, with no limits, totaly free
#26
Hey Sauce,
Don't give up on looking for the way to get the massage function to work.
While I don't "know" any of this for sure, it seems that all of the massage components are in the seat and once you can get power to them then it should work.
#27
Hi
the massage function has a pump and only works with the module =[
I saw a video on youtube about that
#28
#30
With all due respect, the module may select the massage function..... but once it does, it's simply a matter of providing 12 volts to start the pump/controller.
I am not saying you can control it through the seat switches, my take on it would be to provide a 12 volt connection to the massage motor/pump and then see if/how it works.
I'm assuming the MMI is a complicated switch that allows the front seat switch to control a number of function and are selected/displayed via the MMI.
Again, no disrespect as you have done way more than most would ever have tried.
