Audi S8 2016 Brake Thickness
Old 02-11-2019, 08:30 AM
marty7's Avatar
Default Audi S8 2016 Brake Thickness
Hello, new here! I am about to send my S8 for its first MOT and I have a small lip on the brake discs. I was wondering what the original thickness was on the discs and have searched the web and not found it. I have measured with a set of calipers but it's awkward with the wheels on and get an approx. measurement of 36.4mm.
Also remapped this puppy to 700PS and 900NM and really enjoying her!
Thanks in advance for any help here
marty7 is offline
Old 02-15-2019, 10:41 AM
marty7's Avatar
No one? lol
marty7 is offline
Old 02-15-2019, 12:03 PM
Senior Member
MP4.2+6.0's Avatar
Welcome.
You didn't say if conventional cast iron or ceramic. Guessing conventional, but better to be clear.
Also, how many miles on it? As in, how do pads look? If ceramic by chance, that is probably your only watch area unless miles are really high.
I can dig it out w/ known spec. Specs like these are typically service manual level, and as still pretty recent model, few owners seem to wrench on them. alldatadiy is one on line manual and not a big cost one.
MP4.2+6.0 is offline
Old 02-17-2019, 02:10 AM
marty7's Avatar
40k miles. Standard steel with aluminium centres (I was told this is the case although I have never seen the steel ally join). Pads are good so I guess second set. Thanks for your help.
marty7 is offline
Old 02-17-2019, 08:52 AM
Senior Member
MP4.2+6.0's Avatar
Hat join in where you see the axial pins at what looks like a cooling slot area just inside of the swept braking surface. They are not bolts and thus cannot just have the outer ring replaced when needed. Specs below, the S8 being the biggest 400mm ones of course:
Old 02-17-2019, 11:36 AM
marty7's Avatar
That's really kind of you, thanks! So still within the guidelines but next time the pads are done, it will be discs also.
marty7 is offline
clearcut
11-12-2007 10:31 PM
Z3RO
07-17-2006 10:06 AM
dornier
07-04-2005 05:23 PM
bbiiggeezz
12-10-2002 08:06 PM
SteveIAS8
04-25-2002 03:07 PM
Quick Reply: Audi S8 2016 Brake Thickness
