Bang & Olufsen Issue with Bass Clipping In and Out
#21
Price wise is of course the usual difference from one generation to next. For a 2015 you should be looking at somewhat under .8 x .8 x original price = .64, now, just using rule of thumb for the falls like a rock depreciation. Then take another 20% off starting some months ago now as D5 gets close extending to its real into date--on top of an annual typical 20% drop. S8's do a little better, so might not take some of this last compounded 20% model change clip. In plain English, you could pay as little as half w/in the next year for a few year old one at 30K miles or less, or full boat for new. Or, said another way you could have a D4 S8 for less than D5 V6 money. Price has a way of settling these things...
I got B&O on S8 (CPO). Though, until I boosted pre amp levels via Hidden menu I actually wasn't that convinced of the incremental delta from the Bose in my D3 W12. It is tighter and purer but it isn't night and day for my casual ears unless I focused on it. With elevated pre amp and therefore higher volumes, the clarity became more obvious and stronger tight bass (genuine, not thumper or just loud and muddy) was also a better distinguisher.
#22
This sounds early/optimistic. Hasn't even been announced yet, let alone shipped in Europe, which should be 6+ months ahead of here. They also are still running S8's, which they would likely cut off before end of last A8 production run if they follow D3 pattern. On D3's they ran S8's and W12's through spring of next to last model year (2009), then did a short run of 2010's in 4.2 only (and in parallel LWB only IIRC).
#23
Yes, the S8 will be an upgrade in driving, in every way. A good price on a second hand S8 will vary by quite a lot, even with that set mileage, depending on options and whether or not it's CPO.
#24
I'm seeing CPOs around 35% below msrp with 15,000 miles. Gives me 4+ years and 100,000 miles of warranty. Do you really think it'll handle and be be more fun to drive versus the e550? Thanks. Regards. Ned.
#25
CPO at this stage of life cycle makes more sense to me than new as is resonating in thread--the long tail warranty period and prior owners take the first now ⅓+ bath. Only contra as of mid 2016 is the Plus added power. But then starting over this next year I would be looking for those CPO likewise if I were in market and didn't want to go the chip route instead. Frankly since the "standard" S8 is already over the top on power anyway, 2015 w/ facelift and the long warranty is plenty nice. From a guy who held out almost 10 years on his prior D3 W12, also bought a year old on CPO and very happy with both that ride and CPO all the way through the warranty years.
#26
I haven't driven an E550, but I've driven the 5-series. Every review I've ever read rates the BMW as a much better driver than the Mercedes, and I consider driving an S8 as much better than driving the 5-series. I can also say even my non-sport A8L I used to have was a much more engaging driver than my current Mercedes, despite the Audi suffering a staggering 250hp/400lb-ft deficit. If I had to say anything negative, it would be that the front end pushes and steering lacks feedback. That said, at least in my Merc, while evidence suggests that the steering wheel affects the direction of travel, the wheel does little to communicate the fact that it assists with the interaction between the tires and the pavement.
#27
In addition to everything else, you definitely have a dealer problem! The dealer should be front and center in coordinating all communications between you and the Audi rep's. Not meaning to pile on but, cannot even imagine the dealer allowing the ball to be dropped so many times!
“C/S THAT FRONT WOOFER ON DASH GRILLE DOES NOT SEEM TO BE SEATED PROPERLY
REMOVED AND REINSTALLED SPEAKER COVER ON THE FRONT DASH.“
Here is a picture of what it looks like when I picked up the car. Obviously, they did not even touch it - even though their reply to the Audi tech was that it must of popped out again.
#28
Glad they fixed your amp issue. Stuff like that can be very frustrating. How is your case of the winds going? You seem to be a big fan of the s8. I'm considering getting a used 2015 but having trouble finding one with the B&O sound system, being an old audiophile, don't want the car without it. Is it the huge upgrade over stock Bose system I'm assuming it is? Did you ever compare the s8 to an s63? Would you buy one of these now with the new a8 due by mid 2017? Thanks. Regards. Ned.
My boss has the S65, it's an awesome car - the Audi S8 is on par with the S65 for over $100K less.
As far as the B&O system. Yes, it is better than the Bose system. Is it $6K+ better, NO. In fact, a friend of mine put a sub-woofer in his 2014 and it made the Bose system sound incredible. The B&O has some great highs and the bass is well defined but not punchy - it lacks severely in mid-range. At the top level volume of 34 (yes, the volume scale is from 0 - 34), the system is not nearly as loud and defined as the specifications would have you believe.
#29
Same issue
I just created an account here because I'm having the EXACT same issue in my 2017 S6 with B&O. Dealer is unable to fix, also tried the swapping of amps, and even verified that it was happening on other B&O systems in their inventory. We have waited 2 months and Audi corporate has not responded to either me or the dealership.
Unfortunately, today I had to file a lemon law claim to refund me the money for the car, seeing as Audi is unwilling to provide a solution.
This post is a little old, did anyone end up with a solution for this?
#30
