Sponsored by:
Sponsored by:
Bleeding coolant system
Old 11-03-2016, 03:05 AM
Chris Brookes's Avatar
Default Bleeding coolant system
Hi, I would like to say hi as I am the owner of a new to me A8l 3.0tdi and have just registered with this forum 😊 I love my car but yesterday the water pump failed, which with 92k on I can understand if it's the original. I've had a new pump and belt fitted but the heater only gets hot when I'm driving, not when I'm stationary. As such I do think I have an air lock, could anyone please tell me if/where any bleed points are on this car please? It's a late 2011 model so assume 2012 model year and is RHD in the U.K. Many thanks Chris
Old 11-03-2016, 06:09 AM
the_duke's Avatar
Chris, I can't help you with bleed points but I can suggest a tool. I started using one of these about a year ago and will never go back to any other method. I've used this tool to fill 3 Audi's and a chevy truck. All three would normally require bleeding the systems of air afterword. No need to bleed using the Vacuum fill tool.
https://www.ecstuning.com/Search/Sit...ool/ES2712734/
Old 11-04-2016, 06:55 PM
Garycw's Avatar
The car car parked in a front higher attitude does help some when filling and maybe bleeding
Old 11-04-2016, 07:33 PM
gk1
gk1's Avatar
If it is similar to S6 there is a bleed point under the front cowl, center front of windshield. You have to loosen the hose clamp and bleed from there.
09S5 (06-05-2022)
Old 11-15-2016, 02:52 AM
Apologies for the late reply. Yes you were correct regarding bleed location. Thank you very much for helping 😊
CasaS4blanca
06-03-2009 09:10 PM
S_noob
Audi Original "S" Cars
07-13-2007 09:32 PM
Nogaro Stg3
06-05-2006 05:09 AM
Lilcarlson2
11-27-2004 01:14 PM
Audi-Impaired
10
06-05-2003 06:12 AM
Quick Reply: Bleeding coolant system
