Camshaft Position Sensor
Old 02-11-2019, 08:19 AM
  #11
Senior Member
MP4.2+6.0's Avatar
Originally Posted by mpelanti View Post
Hi, just purchased a 2011 A8 with the 4.2L CDRA engine. Car is running just fine, no suspicious sounds from the motor hot or cold etc.
However these codes found from the engine module sound a bit alarming:
4113 - Camshaft Position Sensor (G40): Implausible Signal
P0341 00 [032] - Upper Limit Exceeded
8626 - Camshaft Position Sensor (G163): Implausible Signal
P0346 00 [032] - Lower Limit Exceeded
If cleared, both reappear in around 1 week of driving. What do you think about the issue?
The ECM is in version 0004, and according to some Russian sites engine ECU update to version 0006 could fix the problem.
Yes, likely faulty cam sensors in the positions indicated--or their wiring. The reason for the week or so delay actually also ties to it. The car/ECU runs a self diagnostic on them periodically. From D3 experience it only occurs with engine warm and you are just cruising along with easy throttle at mid speeds and fairly low rpm. Test itself is designed to try to be unnoticeable. If it tests twice with unexpected results, the code comes out and CEL on. From D3 experience that can be a week or two; somewhat shorter if doing long drives.
MP4.2+6.0 is offline
Old 02-21-2019, 05:05 AM
  #12
In my case the errors seem to appear only on car startup, not while driving.
ECU was updated today to revision 0007:
Address 01: Engine (------CDRA)
Part No SW: 4H0 907 560 HW: 4H0 907 560
Component: 4.2l V8/4V H07 0007
According to dealer, also transmission update was required with this ECU revision, so that was also updated:
Address 02: Auto Trans (J217)
Part No SW: 4H1 927 158 CQ HW: 0BK 927 156 K
Component: 0BK 42 FSIRdW H08 1008
Now I will monitor the situation and see if camshaft errors reappear. It they do then next step is to replace sensors.
mpelanti is offline
Old 03-06-2019, 07:44 AM
  #13
I also seem to have a faulty Camshaft Sensor(s) which is likely causing other faults. Mine seem to clear themselves out and return within a week as well. My scan results are below.
3 Questions
I see there are 4 sensors total. Are they all the same part # 07L905163C ?
Are the sensors easy to swap out?
Does anyone have an actual photo of the sensors on the engine?
9 Faults Found:
P0341 00 [096] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
10591 - Cylinder 1
P0301 00 [096] - Misfire Detected
10595 - Cylinder 5
P0305 00 [096] - Misfire Detected
10594 - Cylinder 4
P0304 00 [096] - Misfire Detected
10597 - Cylinder 7
P0307 00 [096] - Misfire Detected
16476 - Fuel Trim; Bank 2
P0174 00 [096] - System Too Lean
16498 - Fuel Trim; Bank 1
P0171 00 [096] - System Too Lean
9025 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 189226 km
Date: 2019.03.01
Time: 17:19:04
Engine speed: 676.00 /min
Normed load value: 31.0 %
Vehicle speed: 1 km/h
Coolant temperature: 88 C
Intake air temperature: 10 C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.182 V
Unlearning counter according OBD: 40
AFS dm: 28.5 kg/h
Median injection timing: 1.163 ms
Engine operating condition: Idling
Engine operating condition-Test_Program_Channel 87: 5
BruceLeroy1984 is offline
Old 03-14-2019, 05:18 AM
  #14
This thread in the D3 forum answered all the questions I asked in the previous post. I'm adding the link in case someone else encounters the same issues. I was able to locate the bad sensor and swap it out for a new one. I cleared my fault codes, ran another full scan and everything came back clear.
Old 04-20-2019, 06:48 AM
  #15
Default Expensive fix!
I had same problem. There's a TSB out http://australiancar.reviews/_pdfs/A...7-2_201607.pdf related to this. Dealer quoted me $10,000 USD to fix it! I'm 7K miles under warranty but 6 months over. Raised a stink and they are fixing it all under warranty.
Eric Stoll is offline
Old 05-02-2019, 03:32 PM
  #16
Ok, the dealer has had the car for 3 weeks now. They're fixing all under warranty (even though warranty expired 6 months ago). All they can tell me is, "there is possible piston issue with the vehicle and they had to order more parts." Does anyone know if this TSB I posted would cause longer-term damage to the engine? Related to the piston? And if they have this thing for a month, how do I know they're fixing it right? It is a good dealer in Atlanta but still!
Black Magic
15
12-23-2015 01:47 AM
relias15
12-19-2015 12:14 PM
DakotaC
Audi allroad
12-17-2015 06:20 PM
Dave Brown
A6 (C7 Platform) Discussion
12-10-2015 12:58 AM
John Elway
12-04-2015 07:37 AM
Quick Reply: Camshaft Position Sensor
