Consistent low boost, A8 4.0
#11
UPDATE:
Had a shop scan it, came back with many fault codes, but the relevant one was this:
10622 - Turbocharger Bypass Valve 2
P00C0 00 [047] - Electrical Malfunction
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 196056 km
Date: 2018.08.26
Time: 20:10:59
Engine speed: 2158.00 /min
Normed load value: 62.0 %
Vehicle speed: 67 km/h
Coolant temperature: 71 °C
Intake air temperature: 40 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 13.193 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
They noted that the electrical connector for the bypass valve was not plugged in all the way. They plugged the connector in all the way, cleared the codes and drove it and it felt better. I did notice a difference when I was driving home initially but it quickly was limiting boost again =(.
The shops guess is the ecu can't communicate correctly with the bypass, either because it's broken or there's a connection issue, so the ecu is limiting boost just to be safe.
The other engine codes were:
14627 - Fuel Pump Control Module
P025A 00 [032] - Electrical Fault
Intermittent - Not Confirmed - Tested Since Memory Clear
14629 - Fuel Pump Control Module
P025C 00 [032] - Short to Ground
10058 - Fuel Pump
P3045 00 [096] - Electronics Defective
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [032] - -
10595 - Cylinder 5
P0305 00 [032] - Misfire Detected
10598 - Cylinder 8
P0308 00 [032] - Misfire Detected
10596 - Cylinder 6
P0306 00 [032] - Misfire Detected
10597 - Cylinder 7
P0307 00 [032] - Misfire Detected
10205 - Cylinder Disabling
P130A 00 [032] - -
They weren't too concerned with these, as there's no symptoms of misfire nor of fuel delivery issues.
I will have the shop scan it again tomorrow and see what codes popped back up regarding the boost issue. I'd scan it myself but Ross Tech is closed until January, so I can't order a VCDS until then =(.
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 196056 km
Date: 2018.08.26
Time: 20:10:59
10058 - Fuel Pump
P0300 00 [032] - -
10595 - Cylinder 5
10598 - Cylinder 8
10596 - Cylinder 6
10597 - Cylinder 7
P130A 00 [032] - -
#12
You might poke at the fuel pump control module codes. Search on it (codes) relevant to Audi, and hopefully specific to 4.0T but at least the ones with direct injection (FSI) and preferably boost. I think that may be referring to some specific electronic control device/box, though haven't run into it before personally. Also, note all the misfire codes are on one side--what will be called in Audi-ese Bank 2, or USA driver's side. In that vein run down the fuel pump code to see if it ties to the same side of motor. If so, also suspect that HPFP on the driver's side. But before cgoing there, make sure the fuel pump control module is in order/fixed and not generating codes again. Though I don't know the part, but it sounds from the scan description like it is probably in front of the HPFP's electronically.
Do you know history of car BTW? Did it have a clean CarFax? --assuming/if you bought used.
#13
I would agree that all those codes are concerning, at least to me. When you see errors regarding fuel delivery and misfires, they should be regarded and solved. These should NOT exist and a mechanic that isn't concerned is probably someone you should stay away from.
Before you move on to other things, attack the obvious. The diverter valve error and the subsequent loose plug, that when plugged in resulted in better performance temporarily. It is possible that one of the pins has become dislodged in the plug and only made very temporary connection when plugged in. Need to have a very close look at the plug and insure the pins are in fact still inserted in the plug so they are making proper contact when plugged in.
Unplug it, pull any cover back and pull on each wire going into the plug while you observe the inside of the plug for movement etc.
Also, you seemed to indicate some amount of work was done that may coincide with the power reduction. You may also want to check air metering. These types of cars typically use a MAF to measure incoming air and a MAP to measure after turbos. If you accidentally tear wire or unplug a MAP the ECU will not throw a code but it will limit boost to about 5-8psi because it can't measure boost.
Good Luck, keep at it and you will find it.
#14
So it's been about a week since the shop scanned it, finally got my VCDS in. I've done numerous pulls, trying to make the car log any kind of error, over the last week. Below is the latest scan. I'm just perplexed by there not being any engine codes at all. It is very noticeably under-powered, which correlates with the lack of full boost pressure. You would think if the ECU is specifically pulling fuel/timing/boost it would be because of some fault. I think the next step would be to start logging using the VCDS, but not sure what I should be looking for. Any help is appreciated. Latest scan is below.
Tuesday,08,January,2019,21:09:20:30925
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.4 (x64) HEX-V2 CB: 0.4437.4
Data version: 20181017 DS296.0
Ross-Tech: Home
VIN: WAUR2AFD8DN018978 License Plate:
Mileage: 205089km-127436mi Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 20 28 34 36 3B 3C 42
46 47 52 53 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90 BA
VIN: WAUR2AFD8DN018978 Mileage: 205089km-127436miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUA) Labels: Redir Fail!
Part No SW: 4H0 906 014 L HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0005
Revision: NCH62---
Coding: 022A00326546010E1000
Shop #: WSC 24876 002 1048576
ASAM Dataset: EV_ECM40TFS0114H0906014L 001005
ROD: EV_ECM40TFS0114H0906014L.rod
VCID: 2C0106C5B68CBBB7123-8078
No fault code found.
Readiness: 0010 1101
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4H1 927 158 EE HW: 0BK 927 156 AG
Component: 0BK 40TFSIUSA H16 1002
Revision: --H16---
Coding: 000001
Shop #: WSC 03200 002 1048576
ASAM Dataset: EV_TCMALX51011 002022
ROD: EV_TCMALX51011.rod
VCID: 77ABE9A93F4AC86FAF1-8022
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 E HW: 4H0 907 379 E
Component: ESP PREMIUM H10 0352
Revision: -------- Serial number: --------------
Coding: C4E5F30023A7CF00E200
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 34311EA56EBCE3774A3-8060
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 DD HW: 4H0 907 064 CD
Component: BCM2 2.0 H33 0510
Revision: 00002001
Coding: 0DA72046000000000000
Shop #: WSC 54994 000 1048576
VCID: 6E85CCCD409089A77C7-803A
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 2312000255529015
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000044942180
Coding: C018320085047201010001010101112131313333283333
Shop #: WSC 02313 785 00200
VCID: 353723A16546FA7F7DD-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 L HW: 4H0 820 043 L
Component: Klima 4 Zonen H20 0121
Coding: 688123BE7C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 290FFFD1B97EAE9FE95-807C
2 Faults Found:
0137 - Motor for Right Side Window Defrost Flap
B10D8 22 [008] - Signal Amplitude Too High
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 205079 km
Date: 2019.01.08
Time: 20:42:06
0194 - Position Sensor in Left Center Vent
B10E1 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 148
Mileage: 205079 km
Date: 2019.01.08
Time: 20:42:11
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001655710
Coding: 09072091077C9FE38B000804A0003800009CD3088E00012180 01085C7B00
VCID: 6FBBD1C9479A80AF771-803A
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 120922 H35 0080
Serial number: 121103104957
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10297266
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B
Component: E1 - LDS H07 0044
Serial number: 20 11 2012 00000861
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R40T102
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000016111200010558
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000019111200010464
Coding: 100000
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA104521000002329985
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: FB384C56000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061232601674
Coding: A80B0E
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71BFD7B1512E965F615-8024
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4H0 907 561 B HW: 4H0 907 561
Component: ACC3 H19 0400
Serial number: 00000000000000
Coding: 7E01020101
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2A0D00DDBC78A587E0F-807E
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H44 0041
Revision: -------- Serial number: 003JS001E16T
Coding: 303143303230303030314A55304C34483053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 372B29A97FCA086F6F1-8062
Seat occupied recognition:
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R12B06060XY
Coding: 000000
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40511OC1G2ORK
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB404T1M57I40PN
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB401I4UOUICOEZ
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB405T1NOT47PGO
Crash sensor for front airbag: driver side:
Serial number: 3554VRB40104UO106HMN
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400A4UO10IH8V
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LKG00028
Coding: 0004BC
VCID: 38292A957254071766B-806C
Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L
Component: E221 - MFL H09 0010
Serial number: 12 09 2012 D1068766
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4H0 920 980 K HW: 4H0 920 980 K
Component: TBenUSAACC--- H50 0515
Revision: 34081076 Serial number: 658231112592006
Coding: 0B4608015740D705020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 33331DB96BB2E44F539-8066
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 G HW: 4H0 919 204 G
Component: Analoguhr D4 H05 0225
Serial number: 1121026000922
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4H0 907 468 AC HW: 4H0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000751447
Coding: 00ED074800
ASAM Dataset: EV_GatewPkoUDS 001018
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 72BDD8BD5428AD4798F-8026
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 00000000004970552583
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Component: J532_DCDCStab H05 0006
Serial number: 12319001969021200410
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8K0 857 511 G HW: 8K0 857 511 G
Component: FLA H04 0020
Revision: AB001001
Coding: 04018B6B74745D545420363E00
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 K HW: 4H0 919 158 K
Component: Klima Fond H16 0200
Coding: 2000000000
Shop #: WSC 28609 001 1048576
ASAM Dataset: EV_AirCondiHeck 002001
ROD: EV_AirCondiHeck.rod
VCID: 38292A9572D4071766B-806C
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008002
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E050CCD8090C9A73C7-807A
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000044944236
Coding: C0183B0085057201010001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 K HW: 4H0 907 637 F
Component: SARA 6D H02 0053
Revision: -------- Serial number: EJ1BPA7700CPY-
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4H0 907 566 A HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-07
Coding: 0000002
VCID: 2E050CCD8C10C9A73C7-807A
Subsystem 1 - Part No: 4H0 907 568 A
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-27
Subsystem 3 - Serial number: 5F07.11.1200H02000AMS15646ÿ
Subsystem 4 - Serial number: S15646ÿ
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0263
Revision: -------- Serial number: 0000132705270
Coding: 011F1F005E0062C202003017
Shop #: WSC 02312 785 00200
VCID: 48C95A5502B4779716B-801C
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0187682655
Coding: 0106023A00FA7585B0B0C7C402030107000000000000000000 0000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000117369
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.030 H07 0006
Serial number: WOO19145644
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 BK HW: 4H0 947 135 BK
Component: Dachelektroni H11 0080
Serial number: A2012000000000654617
Coding: 010000
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS010 H05 0005
Serial number: WOO1000TRVJ
Subsystem 6 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84325469
Address 47: Sound System (J525) Labels: None
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000000951
Coding: 030000
VCID: 1C61D605E6AC4B37623-8048
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0261
Revision: -------- Serial number: 0000132596827
Coding: 011F1F005E0062C202003007
VCID: 3C213685466C2B37823-8068
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000523936
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B0305D9B382BC8F1B9-807E
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4H0 035 082 E HW: 4H0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 155KY0C7526040
Coding: 020007010000000001
VCID: 2313EDF9DBD274CFA39-8076
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 746 E HW: 4H0 035 746 C
Component: H-BNT-NA H50 0622
Revision: -------- Serial number: 183K/0C7505237
Coding: 020200000001F9EF7D128B1E00000003140001000000000000
VCID: 2A0D00DDBCF8A587E0F-807E
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 4H0 919 604 F HW: 4H0 919 604 F
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDC9300X9ZH
Subsystem 3 - Part No SW: 4H1 919 600 M HW: 4H1 919 600
Component: E380 BDT D4 H11 0110
Serial number: 00000000179962
Subsystem 4 - Part No: 8R0 060 961 E
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0262
Revision: -------- Serial number: 0000132413241
Coding: 010F1F00400062C202003007
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0111
Revision: 11001001 Serial number: 82330JF0064515
Coding: 020A000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
ROD: EV_CamerSysteTopViewAUDI_005_AU64.rod
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 AB HW: 4H0 959 107 M
Component: HDSG-Modul H11 0043
Revision: 10011001 Serial number: 305200248
Coding: 0210044100
ASAM Dataset: EV_DeckLidContrUnit 001032
ROD: EV_DeckLidContrUnit.rod
VCID: 6E85CCCD401089A77C7-803A
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000088839
Coding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6393ADF99BD234CFE39-8036
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H06 0262
Revision: -------- Serial number: 0000132413238
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5014 Serial number: SN120910 0197
ASAM Dataset: EV_GSM2x3Mono 001017
ROD: EV_GSM2x3Mono.rod
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Revision: -------- Serial number: 262130025421000
Coding: E9060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2615F4EDA86081E7C47-8072
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00008768049902
Coding: 766FF2
ASAM Dataset: EV_IVBDriveSideFrnt 001003
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F3B11C9879AC0AF371-807A
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00008768049802
Coding: 366FF2
ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4H0 907 541 B HW: 4H0 907 541
Coding: 7E01020101
ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
ROD: EV_AdaptCruisContr2AU64X_002.rod
VCID: 2809FAD5A2749797F6B-807C
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H31 0041
Serial number: 005000121411127
Coding: 02A19A000111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0066F609031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F17B191AED65F215-8064
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323D18BD94A8ED4758F-8066
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H05 0008
Revision: 00001001 Serial number: 97804001013304
ASAM Dataset: EV_AEMLearAU64X 002016
ROD: EV_AEMLearAU64X_AU64.rod
1 Fault Found:
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 205079 km
Date: 2019.01.08
Time: 20:42:08
End----------(Elapsed Time: 03:05, VBatt start/end: 12.1V/12.1V)-----------
Ross-Tech: Home
Revision: NCH62---
Revision: --H16---
Coding: 000001
Revision: 00002001
Coding: 688123BE7C
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 205079 km
Date: 2019.01.08
Time: 20:42:06
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 148
Mileage: 205079 km
Date: 2019.01.08
Time: 20:42:11
Coding: 0045F7
Coding: 025523
Coding: 100000
Coding: 100000
Coding: 020300
Coding: A80B0E
Coding: 7E01020101
Coding: 000000
Coding: 0004BC
ROD: EV_RBD4K.rod
Analog_clock:
Coding: 00ED074800
Voltage stabilizer:
Revision: AB001001
Coding: 2000000000
Coding: 008002
ROD: EV_SARA2.rod
Coding: 0000002
Coding: 020200
Coding: 010000
Coding: 030000
Coding: 0210044100
Coding: 200000
ROD: EV_Ambie.rod
Coding: E9060000
Coding: 766FF2
Coding: 366FF2
Coding: 7E01020101
ROD: EV_BC7.rod
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 148
Mileage: 205079 km
Date: 2019.01.08
Time: 20:42:08
#15
Scan is not reliable as it stands. As an aside, actually also a direct example for anyone considering buying a used Audi of what to watch for to realize codes have probably recently been cleared.
Look at the readiness codes in the ECU. They ain't ready! As in, shop probably cleared them and so you don't have good data yet, and possible codes or CEL to come.
Yours read: Readiness: 0010 1101
When the car is in good form, they should all be "0"s. In CA, your resultt is an automatic smog test fail for example, and tends to indicate when someone recently reset the check engine light.
Below is a table to give you a sense of where it hasn't yet completed enough self testing to decide if things are in order or not. The secondary air injection and EVAP can both take several cold hot cold cycles to reset to ready if all is in order. Often one of those is the last to reset to ready. The O2 not ready and the cat one would be the suspicious ones to me.
If they eventually all get to "ready" (all "0"'s) but no CEL or codes that will definitely be odd, but too early to judge so far.
OberklasseA8 (12-31-2022)
#17
Here’s a link on how to go about it with VCDS. It’s related to the B8 supercharged engine but, with a little thought, you can certainly customize (if necessary) to be applicable to your engine.
If if nothing else, I learned a lot about how variables correlate and change under different conditions (load, RPM and temperatures for instance).
There’s a lot out there as it relates to boosted Audi engines as individuals try to get the most out of their engines - even before companies like APR release a stage tune (e.g. the crank pulley for the V6 SC engine).
How To: VCDS Logging on B8 S4
Good luck and please share your findings.
#18
D4 in PA
My knowledge of engines is limited to being able to swap or add some fluids and looking at components with a serious look on my face.
I have a new-found appreciation for why they charge me so friggin much when the car is serviced for a problem.
#19
While waiting for the readiness codes to reset, I’d start logging to verify what you’re feeling and potentially add value to the diagnosis process.
#20
Made some runs tonight and did some logging. (I went through and tried to clean up the file but then saved it in the wrong format and lost everything, rip)
I could only log 8 parameters at a time using the "Turbo" function in the VCDS, otherwise the poll frequency would be about a second...pretty useless. So, I had to make 4 separate runs with different parameters. I picked these kind of arbitrarily as I really didn't know what I was looking at.
Also, I did another auto-scan, came back with same results as last time with Readiness reading 0000 0000.
Logs are attached.
1st run: generic parameters, throttle, manifold pressure, etc
2nd run: fuel
3rd/4th run: knock sensor parameters and oxygen sensors
Logs are attached.
2nd run: fuel
