First Oil Change
First Oil Change
Did my first oil change this weekend. There are a lot more fasteners on the skid plate on the D4 compared to the D3. Overall a pretty easy job. 4.0t takes about 9 quarts to refill.
Castrol Euro Formula 5W40 this time for me since it was on my shelf; 502 compliant. Often use Mobil 1 0W40. In my case, it had been a year since prior change, but car still only has 8500 miles. Original owner only put 3300 miles on it in a year plus, so it had the 5K change on his watch. I figure take it another 6500 mile and then use my 1 year/15K AudiCare on the more normal cycle. When I bring it in for a few warranty items, I will find out the outer time limit cut offs for each AudiCare covered interval.
Meantime, did my own 'tweener change. Also, when I went to reset the service interval with VCDS, the oil sensor field said "DIRTY." Not sure if it read that off the actual oil quality sensor, or if the time interval basically forces it to that result.
Polo,
I used Castrol Euro Formula 5W40 also. It's inexpensive on and easy to get from Amazon.
MP,
I reset the oil change interval via MMI and that worked. However there is a "Service" interval as well that I need to reset. I just noticed this morning that it's warning me that service is due in 300 miles. I already replaced the air filter and cabin air filter(pain in the ***) just because I wanted to know what was in there. I tried the SRI reset button on the VCDS main screen but that didn't work. Guess i'll have to dig a little deeper to find the reset.
MP,
Polo,
MP,
MP,
You can reset MMI screen by itself too (from inside MMI screens), but I think that just does a default 10K/one year. Once I did VCDS, I got mine to the 6500 miles and 180 day target I was aiming for in inst. module, and MMI screen also then tied out to it.
You said 5W40? The one you linked is 0W40. Both work/are VW 502 compliant. The OW40 and and 0W30 say European Formula on front and last I looked, were made in Europe. The 5W40 one says US and on back says is made in USA. But says 502 compliant.
I apparently remembered incorrectly. The link I posted is what I bought per my Amazon order file. It does in fact say European formula on the bottle.
I see Amazon is pricing the Castrol pretty cheap now on the 0W40 you linked and in the 5 quart jugs. Last year it was the other way around IIRC and it was the 5W40 that was easier to get inexpensively via jug size. When I was last at the local parts store a few weeks back they were selling the Mobil1 0W40 jugs cheaply too--at the sub $30 discounted Amazon or WallyWorld type prices.
Perpetual Novice
03-10-2008 04:52 AM
SoSlow
14
12-31-2007 08:07 AM
