Front Panoramic Sunroof Shade Issues
Greetings! I am having intermittent issues with the automatic sunshade in front of my 2012 A8. The roof itself operates as it should, but the sun shade has been quirky lately. Sometimes it opens or closes on the first hit of the switch. Other times is just seems stuck in position and no matter how many times I hit the switch it won't move. Then it magically frees up the next time I try.
Any ideas as to what this could be? An issue in the switch?
Funny thing is that when I select rear control, the rear sunshade slides forwards and backwards without an issue (using the same switch).
Thoughts?
Thanks!
Thoughts?
Thanks!
Thoughts?
Thanks!
Thoughts?
Thanks!
Where do you hit to affect the motor?
Solved!
I am having the same problem on by 2012 4.2L D4 on the rear pano sun shade. I have tried to bang the areas around the read shade a few times, but nothing. When I hit the switch, I hear a motor clicking sound, but no action. Mine is stuck open.
Hi everyone - believe it or not (and I found it hard to believe because I have two masters degrees in engineering - however neither in EE) the dealership told me that that the issues in the sunroof shade was due to low voltage output from the battery. So I agreed to have the battery replaced (first time it was replaced in the vehicle) and magically proper function returned! I still have a hard time buying into that theory, since everything else in the car functioned perfectly - including the front sun shade, but it fixed the problem to I am trying not to dwell too much on the $400 I dropped
Trango
Audi allroad
15
01-26-2019 03:01 PM
Maini
07-14-2008 10:53 AM
