Headlight washers
Old 10-20-2018, 12:13 PM
Pointman911's Avatar
Default Headlight washers
I found the one thing that doesn't work on my new to me 2014 A8. The headlight washers pop out properly when requesting wash while lights are on BUT:
1- They don't spray fluid
2- They don't retrack back into the bumper. Have to manually push both in at the same time, then they stay in.
My questions are:
What causes the jets/nozels to protrude from and retract back into the bumper? Is it hydrolic or is it the pump that supplies the washer fluid?
The manual tells me that there is a single 35amp fuse for windsheild/headlight washer so I can't simply pull the fuse and just go without the headlight washer (which would be OK with me)
Might there be dried fluid build-up clogging the ports which does not allow them to spray and in turn does not releive the pressure and allow jets to retrack back into bumper?
I believe I read that someone cleared these nozels with air compressor.
i do understand the pump could be out which is why it won't spray which is why I asked what works the nozzels.
I believe there are separate page for the windsheild and headlight washers.
Any help with this would be appreciated. As we all know WINTER IS COMMING.
Pointman911 is offline
Old 10-20-2018, 12:40 PM
RED HORSE's Avatar
Headlight Washers. The most useless feature of any car I've owned, no matter the brand.
RED HORSE is online now
Old 10-20-2018, 04:06 PM
Is it possible to code this out via vcds?
Old 10-21-2018, 05:21 PM
D4 in PA
TinyElviss's Avatar
Talking
TinyElviss is offline
Old 10-21-2018, 07:57 PM
Phil68's Avatar
@Pointman911: Yes there are options to change headlight washer frequency or even complete deactivation via VCDS:
to deactivate completely (from German STG= Steuergeraet) - I don't know the exact wording in English:
a) select STG 09 (electrical system)
b) STG access authorization -> function 16
c) Enter access code 20113
d) STG adaptation -> function 10
e) channel 20
f) set to 00
g) STG long encoding - function 07
h) byte 18
i) deactivate bit 0
That should work.
Phil68 is offline
Old 10-22-2018, 03:14 AM
e) channel 20
f) set to 00
h) byte 18
i) deactivate bit 0
That should work.
I turned it off yesterday using this approach. Thanks for your input. I often get frustrated after searching so long without googling my problem in the proper way and then find the resolution right after I post the question.
Old 02-13-2019, 07:44 AM
Hmmm...I wonder if OBDEleven can deactivate the headlight washers also.
Verybumpy is offline
Old 02-13-2019, 01:27 PM
spdemon91's Avatar
So true. Especially when the nozzle sprays up all over your freshly cleaned hood.
spdemon91 is offline
Old 02-13-2019, 07:28 PM
Senior Member
MP4.2+6.0's Avatar
Or...when headlights on keep squirts brief and then repeat as wipers go through each pass. How I can usually avoid a lot of wasted headlight washes, or at least did on D3 when I got used to faking it out
MP4.2+6.0 is offline
LIRS6
03-20-2007 12:01 PM
Silver85TC
02-28-2005 11:50 AM
arndtc
01-20-2004 06:12 AM
Pal Sek
02-18-2003 04:45 AM
Rick (Virginia)
01-13-2000 06:59 PM
Quick Reply: Headlight washers
