Heads Up Display Coding A8 UK 2016
I have recently purchased a 2016 model A8 Sport, according to the brochure the ACC/Active Lane Assist should be available as an MMI "content option" for the HUD but it looks like Audi have chosen not enable it. I have even found a video on the UK website with it shown!
Whilst I ague with Audi UK, I have being looking at coding using VCDS.
My HUD Module is 4H0 919 617 A (no label file) whereas most posts relate to 4G8 919 604 L
By trial and error is seems like the coding is very similar as I can control the following HUD menu content items by changing the bits. I can enable everything except (ACC/Lane Assist)
Bit 0 is Traffic Sign Recognition
Bit 1 is Navigation
Bit 2 (should be Lane Assist - but changing this bit has no effect)
Bit 3 unknown
Bit 4 is Night Vision
Bit 5 is Cruise Control - but not ACC
Bit 6+5 is out of range bit 6 on its own has no effect
Bit 7 unknown (poss seat memory)
Although I don't have Night Vision once enabled I can control the state using the MMI Personal Settings in Adaptation.
Does anyone have any more information/ideas. Attached is the scan for the whole car.
Cheers,
Bit 1 is Navigation
Bit 3 unknown
Cheers,
Hi Wanman
Thanks for this post! Coming from am 2012 A7 with a HUD containing all the usefull information like ACC, Lane Assist, ..., I am a bit disappointed of the HUD in my new Audi S8 plus.
I do not fully understand, if you did find a solution to activate the missing information (ACC, Lane Assist,..) in the HUD in the S8 by VCDS coding? If so, can you explain where exactely I have to change which byte in which address?
Thank you very much in advance!
Phil
Phil
Hi Wanman
Phil
Phil
if all is enable you need to use VCDS go to Head-UP Display -> Long Coding -> code blind accordingly to description from post 1. Blind because bytes do not have description in VCDS.
1st check if you can switch on all options in MMI. As far I remember Car -> Assist system -> HUD
For me the first post is not very clear about the exact code. He wrote: "I can enable everything except (ACC and Lane Assist)". So my question here is: Are you sure that enabling ACC and Lane Assist in the S8 HUD is acctually possible? If so, do you or anybody here knows, which bytes must be changed?
Thanks again.
Thanks Rafi for your help. In the MMI there are in fact only three options available (traffic signs, speed and navigation) which I did all activate.
Thanks again.
Thanks again.
Lane Assist will only give you green or red icon on HUD. BTW this is weird that it's not configured on your car since it came from factory which these systems I assume.
I retrofitted Lane Assist and HUD as well so I had to do it.
HUD Mod
Bit 1 is Navigation
Bit 3 unknown
Cheers,
Bit 1 is Navigation
Bit 3 unknown
Cheers,
09S5 (07-10-2021)
HUD + cruice control
Hi,
I did a retrofit of the HUD on my 2010 A8 4H and cannot get the cruise control started in the HUD too.
Does anyone have a idea why the cruice control data is not tranfered?
I did the coding acordonly list below;
Bit 1 is Navigation
Bit 3 unknown
Although I have cruice control enabled I can control the state using the MMI Personal Settings.
Bit 1 is Navigation
Bit 3 unknown
09S5 (07-10-2021)
