Go Back  AudiWorld Forums > Audi Models > Audi A8 / S8 > A8 / S8 (D4 Platform) Discussion
Reload this Page >
Help diagnosing fault code - AUTO HVAC: 0378 - Coolant Circulation Pump
Old 04-12-2018, 07:22 AM
Default Help diagnosing fault code - AUTO HVAC: 0378 - Coolant Circulation Pump
My HVAC system seems to be running fine, but I keep getting the same fault code come up as soon as I run a scan. I did notice a few times last summer the passenger side vents would blow warm air while the driver side vents blew cold air, usually after a cold start but not always, even though the HVAC settings were the same for both passengers. Anyone have this fault code diagnosed before? btw my car is a 2011 A8 swb 4.2 with 73,000 miles, live in the upper midwest.
Address 08: Auto HVAC (J255) Labels: 4H0-820-043.clb
Part No SW: 4H0 820 043 E HW: 4H0 820 043 E
Component: Klima 4 Zonen H14 0063
Coding: 4801207E8C
Shop #:
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID:
1 Fault Found:
B10D0 04 [009] - Internal System Fault
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 147
Mileage: 118148 km
Date: 2018.04.11
Time: 11:46:46
Direwulff is offline
Old 02-18-2019, 10:50 PM
Dit you get it resolved?
supernaus is offline
Old 02-19-2019, 03:22 AM
I had this a while back, here is a little guide how to repair
Word Doc
Albert
Albert_Swafega is offline
Old 02-20-2019, 05:56 AM
I don't remember if this was my code; but if it's the pump on the cowl side of the firewall, the dealer wanted $600 to change it.
ppinto1 is offline
Old 02-20-2019, 06:58 AM
Thx for al the reaction I noticed later this is for the A8. I need a solution for the A6 C7 model.
Old 06-29-2019, 09:52 AM
Default I replaced both pumps and same code
I have the same problem described in this thread. No heat intermittently this past winter, and now no heat period. My vehicle is a 2013 Audi A8L w/ the 4.0t engine.
Here is my code scan from VCDS:
1 Fault Found:
Per the suggestions from this and other threads, I changed the pump located by the fire wall (I used a new "replacement" pump purchased from Ebay $33), and still get the same code. No heat either. After a little more research, I discovered an identical pump down by the Aux radiator in front of the drivers side wheel well. Thinking that was the problem, I purchased and changed that pump (again, I used a new "replacement" pump purchased from Ebay $33) and again get the same code. No heat at all yet. I am out of ideas, and am hoping that there is another avenue to troubleshoot, because I need a direction, other than taking it to the dealer....
john6205 is offline
Maguila
A4 (B8 Platform) Discussion
04-07-2019 04:29 AM
Syfer23
VAG-COM Discussion
04-09-2015 08:47 AM
c4S6
Audi Original "S" Cars
03-17-2008 10:46 AM
Rodrigo Gomes
Audi A3 / S3 / RS 3
08-06-2003 04:51 PM
Boston1.8T
04-22-2003 04:01 PM
Quick Reply: Help diagnosing fault code - AUTO HVAC: 0378 - Coolant Circulation Pump
