Lane assist Fails. have codes
When I try to engage the lane assist it fails. Here is what I get when I read the codes.
Does anyone know where this motor is? In the wheel? Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb Part No SW: 4H0 953 568 H HW: 4H0 953 568 H Component: Lenks.Modul H03 0005 Revision: -------- Serial number: 90815MCA0000A Coding: 0004BC Shop #: WSC 02391 785 00200 VCID: 387F36E08BBA0C84DF-806C Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L Component: E221 - MFL H09 0010 Serial number: 17 01 2013 33333944 1 Fault Found: 02795 - Steering Wheel Vibration Motor (V331) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 39 Reset counter: 101 Mileage: 124124 km Time Indication: 0 Date: 2018.05.10 Time: 12:30:23 Address 85: On Board Cam. (J852) Labels:* None Part No SW: 4G0 907 217 A HW: 4H0 907 217 A Component: DPC-SG H26 0038 Revision: -------- Serial number: 262130025421000 Coding: E9060000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_OnBoardCamerDPC 001007 ROD: EV_OnBoardCamerDPC.rod VCID: 2643E898590E8A747D-8072 1 Fault Found: 0721 - Function Restriction due to Faults in Other Modules U1113 00 [009] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 15 Reset counter: 100 Mileage: 124124 km Date: 2018.05.10 Time: 12:30:26 Outside air temperature: -37.5 °C Voltage terminal 15: 12.6 V Control Module temperature: 43.0 °C |
