Lowering confirmed via VCDS
#51
I went back today and used a very flat and level surface for another calibration. I added 10mm to the front only and left the back stock. It definitely tightens up the ride. It feels like she tracks a little better and less sway in cornering with the sacrifice of a little more rough road transfers to the driver.
It is interesting how when calibrating and setting actual measured height my front left has been consistently lower then the front right by about 9mm. For instance the measured FL is like 408mm and the FR is 417. The rears were within about 6mm of each other. If you are real careful measuring they match almost exactly after calibration is saved.
If any of your settings are exactly the same then I would fix measure correctly. It would be interesting if programmed numbers from the factory are generic. I can't imagine that would be true.
#52
I'm about to lower my car, but I had a question. I always ride around in dynamic suspension mode. So since that lowers the car, what will this lowering through vcds do? Does it affect the stock height only? Meaning when I switch to dynamic it will lower even more?
#53
It will lower the car in all modes.
#54
#55
That's not what I mean at all. When you lower it in vcds you reset the standard height. The height it's normally at when in comfort mode. Dynamic will always be lower than comfort. Someone (probably MP4.2) posted what the actual amount is that the car lowers in dynamic.
#56
Oh ok thanks! Sorry I keep asking questions, but from what I've read, is recommended to not go lower than 17mm. If I go down there whole 17mm and then switch to dynamic, will my car be low enough to cause problems or is it ok to drop that much and use dynamic combined?
#57
The more you lower the worse she is going to ride. It will most likely lead to premature failure of your air-shocks as well. At least this has been my experience with other vehicles. It does look good but not worth
the sacrifice imo. I went back to stock height as I did not like the ride quality sacrifice.
#58
#59
#60
I'm currently sitting at 11mm lowered and it's a nice ride, but I still remain in comfort mode
