Minimum amount of oil to flush/run the 4.2 engine?
Odd q perhaps but its time for an oil change and I was thinking to do a half"ish" fill and run the engine a bit before draining it again and doing the final fill. Anyone have any insights on how much oil I would need doing the intermediate fill, running the engine for a few minutes?
If you want to do something sort of like this a lot more safely, drain oil fully and then pour a portion of a quart of your fresh fill oil in to wash down into the pan and out the drain again. I sometimes do that when the fill quantity is not an even quart. I just use the extra for that extra step in advance, and then am done with leftover part of the final quart. Yes, a bit more in some galleries and pump and such, but not material as a percentage. Getting the new additive pack along with fresh oil and a clean filter is the 99%+ of what's important.
Change the oil more frequently if this is a genuine concern for you. Use the correct spec oil.
That's what I did last time and I was thinking to get it even more clean this time. Obviously I was not intending to do a "half fill" that risked the engine in any way. My q should perhaps have been what's the minimum amout of oil you need to run the engine without any risks for a few minutes?
AlteredEgo79
A4 (B7 Platform) Discussion
03-15-2007 07:42 AM
krue92
09-23-2005 06:51 PM
Jason S8
01-13-2002 05:53 AM
Scott W
16
11-10-1999 01:47 PM
