MMI screen issues
Hello everybody,
For a few months now, I have been experiencing some issues with the MMI screen in my 2015 D4. It started with the occasional blacking out of the screen whenever I activated park assist. It has since then progressed to multiple horizontal lines even without park assist activated. This issue seems to be isolated to the native MMI interface. CarPlay still displays perfectly with no issues at all. I attached a link to a video below for your review. I did a search of the entire forum and did not find anything close to what I am currently experiencing before I made this post. Does anyone have any experience with this particular issue? I ran a VCDS scan and posted the results below if that helps, I did not notice anything significant. Any help will be much appreciated. Thursday,28,October,2021,08:16:08:10161 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4 Data version: 20210903 DS330.0 www.Ross-Tech.com VIN: WAU32AFDXFN015427 License Plate: Mileage: 125006km-77675mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: FD-AU64 (4H0) Scan: 01 02 03 05 06 08 09 13 15 16 17 19 20 28 34 36 3B 3C 42 44 46 47 52 53 55 56 5F 62 6C 6D 6F 72 81 82 84 85 88 89 8B 8E 8F 90 BA VIN: WAU32AFDXFN015427 Mileage: 125006km-77675miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 20-High Beam Assist. -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3B-Sensor Elect. -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 81-Gear Shift -- Status: OK 0000 82-Head Up Display -- Status: OK 0000 84-Night Vision -- Status: OK 0000 85-On Board Cam. -- Status: OK 0000 88-Multicont. Seat Driver -- Status: OK 0000 89-Multicont. Seat Pass. -- Status: OK 0000 8B-Adaptive Cruise 2 -- Status: Malfunction 0010 8E-Image Processing -- Status: OK 0000 8F-Pretens. Frt Left -- Status: OK 0000 90-Pretens. Frt Right -- Status: Malfunction 0010 BA-Motor Mounts -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (------CTGA) Labels:. 079-907-560-CFS2.clb Part No SW: 4H0 906 014 J HW: 4H0 906 014 Component: 4.0l V8TFSI / H62 0005 Revision: NCH62--- CVN: 8A815612 Coding: 022A00326546010E3000 Shop #: WSC 47273 001 1048576 ASAM Dataset: EV_ECM40TFS0114H0906014J 001005 ROD: EV_ECM40TFS0114H0906014J.rod VCID: 2A0D07682C7D524BD95-807E VINID: 9D1943091594A167800451021C2861E327 No fault code found. Readiness: 1110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 4H1 927 158 CT HW: 0BK 927 156 AD Component: 0BK 40TFSIUSA H18 1005 Revision: --H18--- CVN: D757CEB6 Coding: 000001 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMALX51011 002022 ROD: EV_TCMALX51011_002_AU64.rod VCID: 045189D0EE99643B839-8050 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb Part No SW: 4H0 907 379 AA HW: 4H0 907 379 AA Component: ESP PREMIUM H10 0665 Revision: -------- Serial number: -------------- Coding: CCE5F3E033A7CF07E200 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_ESPPremi 005024 ROD: EV_ESPPremi_005_AU64.rod VCID: 71BFD004C12B619358F-8024 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 4H0 907 064 FD HW: 4H0 907 064 ED Component: BCM2 2.0 H36 0551 Revision: 00002001 Coding: 0DA76F4E000000000000 Shop #: WSC 02391 785 00200 VCID: 70B9D500CAA1689B571-8024 Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C Component: J764 ELV MLB H40 0046 Serial number: 0214000122825014 No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass (J521) Labels: None Part No SW: 4H0 959 760 E HW: 4H0 959 760 E Component: MEM-BFS H08 0156 Revision: AA000000 Serial number: 00000110651749 Coding: C018320085047201010001010101112131313333283333 Shop #: WSC 02391 785 00200 VCID: 35372414F5430DB3447-8060 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb Part No SW: 4H0 820 043 P HW: 4H0 820 043 P Component: Klima 4 Zonen H20 0210 Coding: 688122B87C0000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirCondiFront 003001 ROD: EV_AirCondiFront_002.rod VCID: 2D070C741D9345733C7-8078 1 Fault Found: 0245 - Function Restriction due to Faults in Other Modules U1113 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 123 Mileage: 125006 km Date: 2021.10.28 Time: 07:27:53 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb Part No SW: 4H0 907 063 AB HW: 4H0 907 063 AB Component: BCM1 2.0 H20 0242 Revision: 19020001 Serial number: 00000862137801 Coding: 01050011043C9FE2C9004884A0003800009CD308AE08022180 000894710017000060002D0B0000 Shop #: WSC 02391 785 00200 VCID: 6889BD60F271A05B0F1-803C Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB Component: WWS641 140620 H36 0090 Serial number: 140626155028 Coding: 0045F7 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 22948028 Coding: 02004E Subsystem 3 - Part No SW: 4H0 941 531 G HW: 4H0 941 531 G Component: E1 - LDS H01 0044 Serial number: 21 07 2014 00000353 Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A Component: USHL4.2 H30 0030 Serial number: 0000002274555R99N603 Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C Component: EVLS-SG H08 0300 Serial number: WA108556000008247577 Coding: 020300 Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 Serial number: F798CB37000000000001 1 Fault Found: 01229 - A/C Humidity Sensor (G260) 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 123 Mileage: 125006 km Time Indication: 0 Date: 2021.10.28 Time: 07:27:55 ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb Part No SW: 4H0 907 561 C HW: 4H0 907 561 Component: ACC3 H21 0032 Serial number: 00000000000000 Coding: 7E01020101 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContrAU64X 002024 ROD: EV_AdaptCruisContrAU64X_002.rod VCID: 2B03026C23874B43223-807E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:* 4H0-959-655.clb Part No SW: 4H0 959 655 G HW: 4H0 959 655 G Component: Airbag10.43 H63 0083 Revision: -------- Serial number: 003KC0013501 Coding: 303331323130303231384A55304C34483053 Shop #: WSC 53951 001 1048576 ASAM Dataset: EV_AirbaAU10BPAAU64X 001014 ROD: EV_AirbaAU10BPAAU64X_VW51.rod VCID: 3A2D3728DCDDE2CBA95-806E Seat occupied recognition: Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A Component: BF-Gewichtss. H03 0040 Crash sensor for side airbag: driver side: Front Passenger's Side Airbag Crash Sensor: Rear Side Airbag Crash Sensor (on driver's side): Passenger side rear thorax airbag crash sensor: Crash sensor for front airbag: driver side: Crash sensor for front airbag: front passenger side: No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb Part No SW: 4H0 953 568 H HW: 4H0 953 568 H Component: Lenks.Modul H04 0005 Revision: -------- Serial number: 01335NGK001QY Coding: 0004FC Shop #: WSC 02391 785 00200 VCID: 38292D20E251F0DB5F1-806C Subsystem 1 - Part No SW: 4H0 951 528 K HW: 4H0 951 528 K Component: E221 - MFL H09 0010 Serial number: 27 06 2014 A0083930 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1 Part No SW: 4H0 920 880 L HW: 4H0 920 880 L Component: TBenUSAACCNV- H53 0707 Revision: 37081202 Serial number: 658230714592012 Coding: 034708011F51D705020000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RBD4K 004050 ROD: EV_RBD4K_AU64.rod VCID: 33331A0CFBB713836A3-8066 Analog_clock: Subsystem 1 - Part No SW: 4H0 919 204 M HW: 4H0 919 204 M Component: Analoguhr D4 H05 0225 Serial number: 2140625009898 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb Part No SW: 4H0 907 468 AF HW: 4H0 907 468 AC Component: J533--Gateway H13 0075 Revision: -------- Serial number: 00000001513671 Coding: C0ED074800 Shop #: WSC 02391 785 00200 GVL: FF8FE94CFEE3ECCDC1000000 ASAM Dataset: EV_GatewPkoUDS 001024 ROD: EV_GatewPkoUDS_001_AU57.rod VCID: 75B7E414B5434DB3847-8020 Battery Monitoring Control Module: Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F Component: J367-BDM H08 0181 Serial number: 51189B03401911522299 Voltage stabilizer: Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C Component: J532_DCDCStab H05 0006 Serial number: 14232000654021200410 No fault code found. ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels: None Part No SW: 4H0 857 511 A HW: 4H0 857 511 A Component: FLA H04 0020 Revision: AB001001 Coding: 04018B6B74745D545420363E00 Shop #: WSC 02391 785 00200 VCID: 2809FD6032F1605BCF1-807C No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb Part No SW: 4H0 919 158 K HW: 4H0 919 158 K Component: Klima Fond H16 0200 Coding: 2000000000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirCondiHeck 002001 ROD: EV_AirCondiHeck.rod VCID: 38292D20E2D1F0DB5F1-806C No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control (J197) Labels:. 4G0-907-553.clb Part No SW: 4G0 907 553 G HW: 4G0 907 553 F Component: LUFE-DAEMPFER H19 0783 Coding: 008002 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AirSuspe 003025 ROD: EV_AirSuspe_VW51.rod VCID: 2F3B167C179F37630EB-807A No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4H0 959 760 E HW: 4H0 959 760 E Component: MEM-FS H08 0156 Revision: AA000000 Serial number: 00000110651846 Coding: C0183B0085057201010001010101112131313333203333 Shop #: WSC 02391 785 00200 VCID: 35372414F5430DB3447-8060 No fault code found. ------------------------------------------------------------------------------- Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb Part No SW: 4H0 907 637 K HW: 4H0 907 637 F Component: SARA 6D H03 0056 Revision: -------- Serial number: EJ1BPA77020PE6 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SARA2 005012 ROD: EV_SARA2.rod VCID: 372B2E1CEFCFFFA356B-8062 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb Part No SW: 4H0 907 566 F HW: 4H0 907 566 F Component: SWA Master H06 0030 Serial number: 0338798025 Coding: 040211 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_LaneChangAssis 001028 ROD: EV_LaneChangAssis_VW51.rod VCID: 33331A0CFBB713836A3-8066 Lane change assistance control module 2: Subsystem 1 - Part No SW: 4H0 907 568 F HW: 4H0 907 568 F Component: SWA Slave H06 0030 Serial number: 0339172142 Coding: 040211 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb Part No SW: 4H0 959 793 R HW: 4H0 959 793 G Component: TSG FA H07 0280 Revision: -------- Serial number: 0000110805313 Coding: 011F1F005E0062C202003017 Shop #: WSC 02391 785 00200 VCID: 48C95DE092B1805B2F1-801C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb Part No SW: 4G0 909 144 M HW: 4G0 909 144 G Component: RCEPS H41 0011 Revision: 00001000 Serial number: 0023798220 Coding: 101001010001 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RCEPS 009010 ROD: EV_RCEPS_009.rod VCID: 33331A0CFBB713836A3-8066 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb Part No SW: 4H0 907 064 FD HW: 4H0 907 064 ED Component: BCM2 2.0 H36 0551 Revision: 00002001 Serial number: 0342417275 Coding: 0106063A00FA7185B0B0C7C402031647000000000000000000 0000000000 Shop #: WSC 02391 785 00200 VCID: 70B9D500CAA1689B571-8024 Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719 Component: GTO BF H01 0081 Serial number: 00000000000000230133 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591 Component: J245 PS50.030 H08 0006 Serial number: WOO3062606/ Coding: 101F00 Subsystem 4 - Part No SW: 4H0 947 135 BK HW: 4H0 947 135 BK Component: Dachelektroni H13 0080 Serial number: A2014000000000808001 Coding: 010000 Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A Component: V252 PS014 H06 0005 Serial number: WOO10005GMI Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D Component: GEB.F.Heckoef H16 0811 Serial number: 93265261 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4G1 035 223 A HW: 4G1 035 223 A Component: BOSE-G3C7-ANC H02 0540 Revision: CJ002700 Serial number: 00000000011139 Coding: 030000 Shop #: WSC 02391 785 00200 VCID: 1C61D1B076A9BCFB5B9-8048 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb Part No SW: 4H0 959 792 G HW: 4H0 959 792 G Component: TSG BF H07 0280 Revision: -------- Serial number: 0000110849925 Coding: 011F1F005E0062C202003006 Shop #: WSC 02391 785 00200 VCID: 3C213130D669DCFBBB9-8068 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 H HW: 4H0 907 801 A Component: EPB-4 H04 0015 Revision: -------- Serial number: 00000001165114 ASAM Dataset: EV_ParkiBrake 001028 ROD: EV_ParkiBrake_VW51.rod VCID: 2D070C741D9345733C7-8078 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb Part No SW: 4H4 907 357 B HW: 7P6 907 357 B Component: MxB-ECU 001 0049 Revision: -------- Serial number: -------------- Coding: 02F2021122600400 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002 ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod VCID: 313F100401AB219318F-8064 Left LED Headlamp Power Output Stage 1: Subsystem 1 - Part No SW: 7PP 941 472 G HW: 7PP 941 472 G Labels: 3D0-941-329.CLB Component: LED LeiMo li. H07 7540 Coding: E00200 Right LED Headlamp Power Output Stage 1: Subsystem 2 - Part No SW: 7PP 941 472 G HW: 7PP 941 472 G Labels: 3D0-941-329.CLB Component: LED LeiMo re. H07 7540 Coding: E00200 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: None Part No SW: 4GD 035 082 G HW: 4GD 035 082 Component: Radio U SIRIU H65 0133 Revision: AB001007 Serial number: 315G/0E7505278 Coding: 020007010000000001 Shop #: WSC 02391 785 00200 VCID: 38292D20E251F0DB5F1-806C No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4H0 035 746 H HW: 4H0 035 746 F Component: H-BNT-NA H41 0810 Revision: -------- Serial number: 183GZ0EB003264 Coding: 02020000000BFDEF7D16CB1E00000003140001000000000000 Shop #: WSC 02391 785 00200 VCID: 2D070C741D1345733C7-8078 Subsystem 1 - Part No: 8R0 060 884 CA Component: NAR 2014 1002 Subsystem 2 - Part No SW: 4H0 919 604 G HW: 4H0 919 604 G Component: DU8 D4 SV NB H48 0021 Serial number: AUZ8ZDEC901MX4B Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600 Component: E380 BDT D4 H09 0065 Serial number: 00000000166378 Subsystem 4 - Part No: 8R0 060 961 G Component: CD-Database 5950 1 Fault Found: 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 123 Mileage: 125006 km Time Indication: 0 Date: 2021.10.28 Time: 07:28:05 Freeze Frame: Voltage: 13.60 V ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb Part No SW: 4H0 959 795 D HW: 4H0 959 795 D Component: TSG HL H07 0280 Revision: -------- Serial number: 0000107810598 Coding: 010F1F00400062C202003006 Shop #: WSC 02391 785 00200 VCID: 3C213130D669DCFBBB9-8068 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4H0 907 428 B HW: 7P6 907 441 D Component: TopView H05 0220 Revision: 11001001 Serial number: 82330JF0167339 Coding: 020D000001010000000102000000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_CamerSysteTopViewAUDI 007026 ROD: EV_CamerSysteTopViewAUDI_007.rod VCID: 2C01017026894C7B2B9-8078 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (----) Labels:* None Part No SW: 4H0 959 107 AC HW: 4H0 959 107 AC Component: HDSG-Modul H12 0049 Revision: 10012001 Serial number: 192400065 Coding: 021004C120 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_DeckLidContrUnit 001032 ROD: EV_DeckLidContrUnit.rod VCID: 6FBBD67CD71F77634EB-803A No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II (J773) Labels:* None Part No SW: 4H0 907 412 HW: 4H0 907 412 Component: ALM H05 0004 Revision: -------- Serial number: 000000157293 Coding: 200000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_Ambie 001008 ROD: EV_Ambie.rod VCID: 6393AA4C0BD7C303DA3-8036 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb Part No SW: 4H0 959 795 D HW: 4H0 959 795 D Component: TSG HR H07 0280 Revision: -------- Serial number: 0000107810597 Coding: 010F1F00400062C202003006 Shop #: WSC 02391 785 00200 VCID: 3C213130D669DCFBBB9-8068 No fault code found. ------------------------------------------------------------------------------- Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb Part No SW: 4H1 927 731 A HW: 4H1 927 731 A Component: GSM-LL H09 0083 Revision: 0L0D5015 Serial number: SN140704 0044 ASAM Dataset: EV_GSM2x3Mono 001017 ROD: EV_GSM2x3Mono_AU64.rod VCID: 2B03026C23874B43223-807E No fault code found. ------------------------------------------------------------------------------- Address 82: Head Up Display (J898) Labels:* None Part No SW: 4H0 919 617 HW: 4H0 919 617 Component: HeadUpDisplay H16 0021 Revision: 00000000 Serial number: 00000000000000 Coding: D20000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_HUDContiC7 001025 ROD: EV_HUDContiC7.rod VCID: 6D87CC74DD1385737C7-8038 No fault code found. ------------------------------------------------------------------------------- Address 84: Night Vision (J853) Labels:* None Part No SW: 4G0 907 547 A HW: 4G0 907 547 Component: NV-ECU-Gen3 H08 0105 Serial number: 622352400201429 Coding: 211100 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001 ROD: EV_NightVisioGen3AE4AU64X.rod VCID: 2C01017026894C7B2B9-8078 Night vision system camera: Subsystem 1 - Part No SW: 4G0 980 552 HW: 4G0 980 552 Component: NV-CAM-Gen3 H03 0006 Serial number: 623466500F1406600128 No fault code found. ------------------------------------------------------------------------------- Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb Part No SW: 4H0 907 217 F HW: 4H0 907 217 A Component: DPC-SG H27 0081 Revision: -------- Serial number: 262130025421000 Coding: EA060000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_OnBoardCamerDPC 001007 ROD: EV_OnBoardCamerDPC.rod VCID: 2C01017026894C7B2B9-8078 No fault code found. ------------------------------------------------------------------------------- Address 88: Multicont. Seat Driver (J873) Labels:* None Part No SW: 4H0 907 182 H HW: 4H0 907 182 H Component: IVB H07 0042 Serial number: 00017186021101 Coding: 766FF2 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_IVBDriveSideFrnt 001003 ROD: EV_IVBDriveSideFrnt.rod VCID: 2F3B167C179F37630EB-807A No fault code found. ------------------------------------------------------------------------------- Address 89: Multicont. Seat Pass. (J872) Labels:* None Part No SW: 4H0 907 182 H HW: 4H0 907 182 H Component: IVB H07 0042 Serial number: 00017186023802 Coding: 366FF2 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_IVBPasseSideFrnt 001003 ROD: EV_IVBDriveSideFrnt.rod VCID: 2F3B167C179F37630EB-807A No fault code found. ------------------------------------------------------------------------------- Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb Part No SW: 4H0 907 541 C HW: 4H0 907 541 Component: ACC3 H21 0032 Serial number: 00000000000000 Coding: 7E01020101 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContr2AU64X 002021 ROD: EV_AdaptCruisContr2AU64X_002.rod VCID: 290FF864297B5953D0F-807C 1 Fault Found: 12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned C1103 00 [009] - - [FAULT_MAR_PRE_MISALIGNMENT] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 123 Mileage: 125006 km Date: 2021.10.28 Time: 07:27:08 Control Module temperature: 29 ∞C Voltage terminal 15: 13.838 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: 0.29 m/s≤ ------------------------------------------------------------------------------- Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb Part No SW: 4H0 907 107 G HW: 4H0 907 107 Component: BV-SG H32 0084 Serial number: 005000482207147 Coding: 02C19A000111 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_BC7 001001 ROD: EV_BC7.rod VCID: 2B03026C23874B43223-807E No fault code found. ------------------------------------------------------------------------------- Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 945 B HW: 4H0 980 945 C Component: RGS-VL H13 0080 Coding: 0066F609031F0376070308014240C2010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_L 002004 ROD: EV_RGS_L.rod VCID: 313F100401AB219318F-8064 No fault code found. ------------------------------------------------------------------------------- Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 946 B HW: 4H0 980 946 C Component: RGS-VR H13 0080 Coding: 0066F609031F0376070308014240C2010000 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_RGS_R 002004 ROD: EV_RGS_R.rod VCID: 323D1F0804AD1A8B615-8066 1 Fault Found: 12586240 - Internal Control Module Memory Check Sum Error B2000 09 [137] - Component Failure [Electronic Control Unit Malfunction] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 1 Mileage: 109421 km Date: 2020.11.07 Time: 12:07:19 ------------------------------------------------------------------------------- Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb Part No SW: 4H0 907 145 B HW: 4H0 907 145 Component: AEM - LEAR H07 0008 Revision: 00001001 Serial number: 97812004010701 ASAM Dataset: EV_AEMLearAU64X 002016 ROD: EV_AEMLearAU64X.rod VCID: 2809FD603271605BCF1-807C No fault code found. End----------(Elapsed Time: 06:08, VBatt start/end: 13.8V/13.7V)----------- |
Since the display issue clears up when using the CarPlay input we know the display itself isn't toast. Also no smoking gun in the VCDS scan. I would start by opening up the dash and inspecting the condition of your wiring and connections of the MMI unit itself. Maybe something shifted after CarPlay installation.
Originally Posted by iamghana
(Post 25643787)
Hello everybody,
For a few months now, I have been experiencing some issues with the MMI screen in my 2015 D4. It started with the occasional blacking out of the screen whenever I activated park assist. ... I did a search of the entire forum and did not find anything close to what I am currently experiencing before I made this post. Does anyone have any experience with this particular issue? ... Hmmm. Different search algorithm? https://www.audiworld.com/forums/a8-...a8-s8-3013796/ No guarantees around later non-parking (camera) symptoms, but you say that's where it started. If your search was around MMI, consider the other symptoms/factors like camera set up. Also means there are more places to look than just dash. |
Originally Posted by MP4.2+6.0
(Post 25643801)
Originally Posted by virtualrc
(Post 25643795)
(Post 25643801)
