Odometer
Hi all,
I have a 2013 A8 4.0 tfsi, I have noticed the odometer and trip meter are not working. Any idea where to find the problem would be much appreciated Cheers |
just to add the display is ok and showing a mileage just not going up as i drive
Longshot
but have you disconnected the battery for 30 minutes? And retry. |
i will give this a try, thanks
does anyone know where it gets its information from? wheel sensor, BCM, gearbox etc... |
Does the odometer show at all?
Hi,
Yes its showing and i was able to set trip to 0 but not going up |
What do the fault codes say? It's an important clue to what the problem might be.
If you don't have a fault code reader, borrow one from someone who has or buy your own. |
I have a fault code reader and not coming up with anything, i can go further into modules if i know where to look
I asked ChatGPT and it suggested a blown fuse. Seems far-fetched but please have a look.
I will check fuses, worth ago
Thanks |
