Sponsored by:
Sponsored by:
oil over filled
Old 11-29-2017, 10:13 PM
Ricketysplit's Avatar
Default oil over filled
I have have drained my oil twice now and it keeps popping up with "Oil above max level" error.
Old 11-29-2017, 10:17 PM
Default Oil max light
I have have drained my oil twice now and it keeps popping up with "Oil above max level" error. I am wondering if there is a dipstick I could buy for a 2011 4.2 A8?
Old 11-29-2017, 11:07 PM
MP4.2+6.0's Avatar
See my earlier thread for the S8 and 4.0T. It may give you some leads relevant to the earlier 4.2: https://www.audiworld.com/forums/a8-...4-0ts-2897711/
Meanwhile, I would stop draining until you get this sorted--either a real dipstick, or a complete drain from underneath (and including filter), and then filling with factory spec # of quarts. Keep in mind, the issue may well be the oil level sensor, unless you basically know you overfilled it.
Old 11-30-2017, 03:46 AM
Yes sir. I have only drained about 1/2 a quart and am not planning on draining anymore. It comes and goes. Right after I wrote my question the light went away again when I took it for a drive. I did read your earlier thread but finding a dipstick for 2011 A8 seems to be near impossible. I can't understand why Audi wouldn't have a backup device to read oil level, it seems to be a very important thing to have your oil at the correct level. I have written Audi directly and hope to hear back from them, but I won't hold my breath. Thanks for the reply.
Old 11-30-2017, 05:33 AM
LexusLSguy's Avatar
It is important to not overfill the engine by much. It can create unsafe oil pressure levels. Particularly forced induction. That's why it's sensitive. Buy a dipstick.
3.0T 3.0T
4.0T
4.2
Old 11-30-2017, 10:42 AM
the_duke's Avatar
Buy the dipstick MP suggested. It should work for your car as it’s a 4.2 engine dipstick.
Old 12-01-2017, 12:34 PM
EngineeringTruth's Avatar
Default Web link for 4.2 shows wrong item !
3.0T
4.0T
4.2
Your link for 4.2 goes to Audi Online Parts. The page shows a dipstick. However if you order that part, 059-115-418-A what you will receive is the oil tube cap, the same part you are trying to get rid of. I had to ask for a refund when I ordered the part from Audi Online Parts. I spoke on phone to the parts guy there. I guess they are too busy to replace the erroneous image. If you run that same part number against google. You get the image of the oil tube cap.
Old 12-09-2017, 12:13 PM
Silver_Solid's Avatar
Forgive the obvious question, but where does the dipstick install?
Old 12-09-2017, 12:23 PM
LexusLSguy's Avatar
There is a cap or plug in the existing dip stick tube. Remove and replace with stick. On the 3.0 it's on the right at the front of the engine.
Old 12-20-2017, 06:01 PM
Karrera4's Avatar
Just did the same damn thing. Can someone confirm that actual p/n for the dipstick for a 2015 S8??
Quick Reply: oil over filled
