placement of jack stands
Would appreciate advice where to place jack stands property on all four corners.
Originally Posted by blsching
(Post 24466274)
Still waiting for some helpful comments. Where to place a jack stand after jacking up the car with the jack provided by Audi?
(Post 24467387)
My only advice would be to look in the manual or the erWin guides. |
2 Attachment(s)
Originally Posted by jakematic
(Post 24467455)
Since the model is still fairly new, I doubt many people have done this yet - hence the lack of response.
^ He probably means at the junction of the control arm and the shock/air spring assembly. There's usually a solid area there that will easily hold the weight of the car.
Looked through all of the erWin guides this morning and this is the only reference:
• Place jack stands only at locations specified by manufacturer. The vehicle lifting jack supplied with the vehicle is intended for tire changes only. Use a heavy duty floor jack to lift the vehicle before installing jack stands. Fat lot of help that is- they must figure it will always go on a hoist at the dealership... |
i took a peek of the underside of the car. It it difficult to make out what to do; most of it is covered up.
I will visit the dealer and see what I can learn. I always place a jack stand, in addition to the jack provided by the mfr, under the car when I need to change tires. |
(Post 24469576)
I will visit the dealer and see what I can learn. I always place a jack stand, in addition to the jack provided by the mfr, under the car when I need to change tires. Don't know if this helps. Take a look under the car, it may be the same. |
Originally Posted by Boostedws6
(Post 24470166)
I can only speak for the A7. There are plastic cylinder cups that the jack plugs into. The cylinder cups on the undercarriage are recessed to allow the jack to properly seat.
