Sway bar links
#51
I did it with both sides in the air initially, but had to put it back on the ground to get the sway bar back attached to the links. Final tight just means make sure the wheels have the full weight on them when the bolts are tightened, else they may be loose when set back down and still make noise. I don't have a torque spec for you, other than to say tighten it down to about where they were when you took them off. I'd bet you could do it from a pit or the car on ramps without issue. Clearance was the only problem I had with it on the ground.
#52
As a side note, do not work under the car if it is only supported by a jack. Ever, no exceptions.
#54
Well, that's unfortunate. I'm sorry you're having to do it twice so quickly, but it's a cheap lesson in the dangers of unproven aftermarket parts. Especially considering even the factory ones have a relatively short life. At least it's an easy fix.
#55
I believe I had to have mine replaced due to the clunking sound over bumps but my car is CPO'd so dealer did it gratis. Dealer also said I was the third person in that week with this issue.
#57
Too cheap, not sure that will last for you. The part number is 4H0411317C, but if you're not buying it from a dealer's site or storefront, make sure it's Lemforder. I'm not sure the best place to buy there in the UK, but if it helps your search, it is also called a stabilizer link.
#59
Link Stabiliser for your AUDI A8 (4H_) 3.0 TDI quattro (250Hp)
Can't finds lemforder but I found them , any good ? I will also ring audi tomorr,to check how much they charge
#60
