2007 Audi A8L - Adaptive Air Suspension-Yellow Car 🚗 lit continuously-Regarding.
Hi,
I’ve 2007 Audi A8L with 50K miles. I noticed a yellow car light glowing continuously. I can explain the sequence of things that takes place befor the light glows continuously.
1. When I start the ignition, on MMI screen, I could see all 4 options selectable (Lift, Comfort, Automatic & Dynamic).
2. At this point I can select any of the options and start driving the car.
3. After I drive may be for 5 minutes or so, the system is defaulting to Dynamic and rest other options are grayed out. The moment it grayed out, the yellow car light symbol lits on the dash and it glows continuously.
4. This pattern is consistent and it started a week ago. I drive the car daily to work less than 4 miles one way at the speed less than 35MPH.
5. I did checked the body how high it is from the wheels. Noticed the body is approximately 4” high from the front wheels and around 3” high from the back wheels.
6. When I check the manual, it is said the vehicle must be seen at the dealer ASAP if yellow light glows continuously.
7. I am not sure if any of the members faced the similar issue? If so is there any solution that can be fixed ourselves or it has to go to dealer and spend thousands of bucks.
Any help, insight, suggestions are greatly appreciated.
thanks
TT2345.
thanks
TT2345.
You might want to post the same in the D3 forum, this is for the newly released A8. Sounds to me like you have a suspension air leak or a bad valve block. Do a search in the D3 forum and you should get all the answers you need. Good luck!
TT2345
12-04-2018 06:34 AM
mshan
07-06-2008 06:23 PM
Sarge
24
01-03-2007 10:23 AM
Santa Monicar
Audi allroad
10
12-15-2004 09:20 AM
