Adding SIM card?
Adding SIM card?
Unsure if the US's center storage faceplate/baseplate includes a slot to use your own SIM, but if not, wondering if this may work.
I believe all vehicles in NA have an eSIM built in that utilizes AT&T for Audi Connect data services. I believe it's possible to add a SIM card in Europe such that, at the very least, a mobile hotspot can be setup using that SIM card. I doubt Audi Connect can use that SIM card for data, but I can't seem to definitively find out.
The problem though is that the faceplate/baseplate on my D5 does not have a SIM card at all, and Audi Canada has stated that the faceplate/baseplate is such that the SIM card is blanked out.
So, I want to see if it's possible to just plugin a SIM card by bypassing the faceplate. If so (e.g. the slot exists behind the plate), would the MMI system automatically give me the option to use said hotspot?
Instructions included. I may try this later on today....
I've been searching through every Audi forum I could find to see if anyone has tried this on any model and no bueno. Does anyone recall this being attempted before I tear open my D5 again?
To close the loop on this, yes, this is do-able on the D5. You have to enable the external SIM card to be used via OBD11, but very much do-able. You would then manually enter the APN settings for the SIM card you added.
Or, you can have the MMI connect to a hotspot too instead of being its own hotspot.
If this is of interest to anyone, just reply to this thread and I can provide instructions. Nothing too crazy or difficult to do. The main blocker is for us NA people to remove the center glovebox, and then change out the faceplate that is currently blocking the port that the UK folks have which is the slot for the external sim.
Hi Angry. To make MMI connect to my cell phone hotspot, do I need the SIM slot, or is that a setting in OBD11 or existing electronics settings? I was able to connect my rear TV screens to iphone hotspot with ease once the Audi internal hotspot trial ended. Thanks for the post and help.
AudiConverted (07-24-2021)
Audi Fanboy!
Thanks for responding. I don't have the faceplate. Where can I get that? I am not handy with fiddling with cars so I'm more then likely going to have it done for me by an Independent Audi shop owner.
you'd have to find the part number, order it from the dealer, and if your case have someone do the install. That's a setting to change to go from esim to sim but no one here has done or tried this. Good luck!
Does doing this allow for me to get Google Earth and Search functions similar to what Audi Connect does (which costs to much monthly IMO) ? If not, what exactly am I able to get if I do this ?
Frenchpeach
05-30-2018 09:38 AM
