Audi Logic At Its Best - Renaming Performance Designations
You just can't make this stuff up...
BY: JEFF PEREZ, Editor Motor1
Every new Audi will include a number ranging from 30 to 70 on its backside.
Audi’s current vehicle lineup is symbolized by a single letter, followed by an accenting number, representing both the class and type of vehicle. Pretty straightforward. The A1, for example, is the smallest car-based offering in the lineup, and the Q7 is the largest SUV offering (until the Q8 arrives, at least).
But now Audi is deciding to make things even more complicated, for reasons we can’t fully understand. Two numbers will now be added to the back of every Audi vehicle alongside the current model designation and engine type. The numbers will depend on power output, and will range from 30 to 70.
The number "30," for example, will appear on all models with a power output of between 109 and 128 horsepower (81 and 96 kilowatts). The number "45," meanwhile, will reference a power output of between 226 and 248 hp (169 and 195 kW). The number "50" will represent cars with an output of between 281 to 308 hp (210 to 230 kW), and "55" will signify cars with an output of 328 to 368 hp (245 to 275 kW).
Audi Double-Digit Power Designations Audi Double-Digit Power Designations Audi Double-Digit Power Designations Audi Double-Digit Power Designations Audi Double-Digit Power Designations Audi Double-Digit Power Designations Audi Double-Digit Power Designations
5525
At the top of the range, the number "70," will signify Audi’s performance class, with models producing more than 536 hp (400 kW). Each of the numbers will be placed alongside TFSI, TDI, G-tron, or E-tron badges that may already be present. The chart below should help you somewhat decipher the confusing new nomenclature:
30 = 109-128 hp (81-91 kW)
35 = 147-160 hp (110-120 kW)
40 = 167-201 hp (125-150 kW)
45 = 226-248 hp (169-185 kW)
50 = 281-308 hp (210-230 kW)
55 = 328-368 hp (245-275 kW)
60 = 429-455 hp (320-340 kW)
70 = 536+ hp (400+ kW)
The number combinations are said to better identify Audi’s product range, especially those with electric and hybrid powertrains, as well as represent a hierarchy within the brand’s overall model range. "As alternative drive technologies become increasingly relevant, engine displacement as a performance attribute is becoming less important to our customers," explained Dr. Dietmar Voggenreiter, Board of Management Member for Sales and Marketing at AUDI AG.
"The clarity and logic of structuring the designations according to power output makes it possible to distinguish between the various performance levels."
The changes will begin with the new Audi A8, which will be available beginning this fall. The two six-cylinder engines will be predesignated with "50 TDI" and "55 TFSI" badges, representing power outputs of 286 and 340 hp (383 and 455 kW) respectively. In the months that follow, all Audi models will be launched with the new designation.
Source: Audi
5525
Source: Audi
I understand what Audi is trying to do here but who in their right mind (aside from enthusiasts) would remember that 50-TFSI or TFSI-50 would mean a car equipped with an engine rated between 281 to 308 HP? I won't and I consider myself a VW/Audi enthusiast!
I suggest just sticking with engine displacement. If it is equipped with a 2.0L TFSI, Just say, '2.0L TFSI-4'. Or, '3.0L FSI-V6' for a vehicle equipped with a 3.0L FSI V6 engine.
Can you imagine having to dig up a cheat sheet because you forgot the difference between an R8 60 TFSI and the R8 70 TFSI? It is much easier to understand the difference if they just went with 'R8 4.2L TFSI-V8' and 'R8 5.2L TFSI-V10'.
There are gaps in those power ranges. For example, the B9 A4 2.0T with 252 hp would fall in between 45 and 50. Are they going to call it 45.9 or round up to the next higher range? The least they can do is have ranges with no gaps.
I guess it's a roll out with all models' engine ratings falling in line to conform over time. I still think it's dumb, and that the TDI and TFSI engines should be denoted by their displacement numbers. The e-tron and hybrid variants could go with the new nomenclature system.
Well granted here in the U.S we won't get any number smaller than "45" (most likely). I don't see it as confusing as other people do. Plus I think it would roll of the tongue easier. "What model do you have?" It's an A8 55.
As far as S and RS models are concerned this nomenclature WILL NOT affect them. They will remain untouched as they should. So that will also save people from headaches
Since were on the D5 forums as far as the A8 goes this is the lineup (U.S we will probably only get the EWB version, since they killed the SWB for the U.S in late model D4s)
-A8 55 (TFSI)
-A8 60 (TFSI)
-A8 70 (TFSI)
About the "70" badge... I believe that will probably be reserved for the W12. Why?
- It's the biggest number in the range for the biggest engine in the range. It sounds "bigger"
- It's the ONLY car in the Audi line up that has over 536hp, that is not an S or RS model. And again, since those will be immune to the new naming system, I can't see it being applied to any other vehicle.
I might get flamed, but honestly, It's not that complicated
-A8 55 (TFSI)
-A8 60 (TFSI)
-A8 70 (TFSI)
