Hot Phone from Inductive Charging Unit
#11
I drove 50 miles yesterday and my phone overheated again. Interesting idea that the position matters. I will try and test around with that, but I could see where you place the phone might make a difference.
I also think the wireless charging seems like it charges pretty slow. Haven't calculated it yet, but what do you all think?
#13
#14
Just returned from my business trip...my phone didn't overheat to the point of a message appearing on it that it needed to cool off before being used--but it did become quite warm....much warmer than I remember from November/December usage. (This is with the 4 piece plastic corner kit that centers the iPhone X from side-to-side.) Will need to continue to use it to determine if this is a true solution to the overheating.
#16
There is nothing better than charging a phone via a USB cable, FWIW.
#19
Attached are 2 pics:
1. First one shows the 4 corner pieces as installed on the charging surface.
2. Second one shows one of the pieces removed so you can see the slim wedge piece that fits along the side of the rubber pad. It's not obvious looking at the charging surface, but there's a seam where the wedge portion fits along the sides.
4 corner pieces installed
Removed one corner piece to show its slim wedge bottom section
