1994 A6 2.8 auto gearbox issue
Hi
Hopefully someone can assist . I've search the net and haven't had any luck
My auto gearbox, while driving, suddenly had no drive Car has reverse but no forward gears
Checked fluid level - fine
Replaced transmission and torgue converter Both gearboxes do the same
The transmission lever was not replaced. Kept the original unit
Of anyone had had a similar problem or can shed some light, would greatly appreciate it
Check for corrosion on the transmission fuse(s) under the passenger side floor-board. The fuse is on a plastic bridge along with a fuel pump fuse and one or two more. Some transmission problems have been solved by cleaning and replacing the fuse(s).. remember those connections may not have touched in 24 years.
The image is for an earlier car..buts fuses are in the same location.
atgordon
08-14-2014 02:50 PM
