Engine does not start!
I drove it quite a bit today without any abnormal behavior. After being parked for 6 hours it totally refused to start this evening. It spins around, but there is no sign of ignition. It behaves like if there it's out of gas, but the tank is half full.
I can hear the fuel pump start when I turn the ignition on. The self-diagnostic display shows OK.
What is the best way to locate the problem?
Thank you
-pg
You're fuel pump may be running, but that's not going to help if your fuel filter is plugged up.
You're car might turn over, but it's not going to start if the cylinders aren't getting spark.
So, you need to figure out which of these two things are missing first.
1. Check the distributor cap for chip or crack. The car will not or have a hard time starting if there's a crack or chip.
2. Check to see if fuel are getting into the engine. The easiest way to do this is to disconnect the air intake hose and spray a little carb cleaner or starting fluid in there while having someone turn the ignition. If the engine start, fuel is not getting in there (Check your fuel pump and filter).
3. Check your plugs and wires. Use a timing gun if you have it. If not, unscrewed all the plugs and test it. If there's no spark, you may want to check the rotor inside the distributor cap.
Hope this help.
For some reason it started like nothing was wrong today. And it runs as good as it always does.
Why didn't it start last night? Could it be something electric that only works when the weather is warm? Or is it that it just don't like to be parked too close to Rite Aid?
I would like to know what was wrong, so I know I can trust it again.
Distributor cap, rotor, sparkplug cables and sparkplugs was replaced 5k miles ago, so I'm sure that was not the problem.
I could hear the fuelpump start, so I guess the fuelpump works.
Engine is running smooth at all speeds, and also during accelleration, so it doesn't sound like fuelfilter problem eighter.
What could be wrong?
-pg
It didn't have any problem starting last night.
I have an extra cap, so I can try replace it whenever it happens again.
-pg
Zoran in Toronto, proud long time owner of 2 type 44 Audis.
