Engine is 'pinking' or 'hunting'
Old 08-03-2003, 03:01 AM
New Member
Andyr_123's Avatar
Default Engine is 'pinking' or 'hunting'
I bought a 1993 Audi 100 about 2 weeks ago.
I filled it up with 77 litres of Shell Optimax unleaded fuel which i believe has an octane level of about 98/99.
Since then my engine has been 'pinking' ('hunting'). Is it the fuel i put in that's the problem?
Also when i start the car when it's warm (it's fine when i start it cold 1st thing in the morning), the Revs go down to about 600/700 RPM, then up to about 1200RPM and keep going up and down for about 10/15 seconds, also the car occasionally back fires.
Any ideas what could be the cause? (I had one suggestion of it being the fuel pump, does this sound right?)
thanks
Old 08-03-2003, 06:04 AM
AudiWorld Expert
MikTip's Avatar
Sounds more like timing & ignition problem?
Old 08-03-2003, 10:27 AM
20VT90q's Avatar
Default Re: Sounds more like timing & ignition problem?
Also look at the o2 sensors, my bet is they need to be changed. I had a "hunting" idle before they were swaped out, bad fuel economy too. Backfiring can be a sine of fuel delivery issues as well.
Old 08-04-2003, 10:14 AM
New Member
Andyr_123's Avatar
I have adjusting the timing very slightly.
This has definitely improved the 'pinging'.
I think the pinging is still there but it's not very noticable now. i will see how it goes over the next few days and adjust it more if necessary.
thank you very much for the advice....very helpful
Old 08-09-2003, 08:58 AM
New Member
Andyr_123's Avatar
adjusting the timing has stopped the engine hunting and mis-fireing, however the 'pinking' is still there.
i don't really know what it could be to do with.
has anyone elses engine been 'pinking'? if so, how did you overcome it?
thanks
arran
05-05-2011 10:49 AM
poolemit
06-12-2009 05:45 AM
1atlantis
02-07-2006 11:35 AM
lwberkley
Audi 100 / A6 (C4 Platform)
08-19-2003 05:56 PM
phkodack
05-04-2002 07:24 AM
Quick Reply: Engine is 'pinking' or 'hunting'
