Fuel gauge
Fuel gauge
I own audi 100, everytime my fuel gauge reaches 1/4 tank, I rushes to 1/8 tank. What could the cause?The other thing is, it goes up as the revs go up.
Non-dampened gauge early style...could be a few things...there is a voltage stabilizer in the instrument cluster that would explain the fluctuations when reving the engine. You will need a Bentley manual. The voltage stabilizer will cure a lot of issues with your gauges. Part number 171919803
In 1988 the Audi was called a 5000 in the USA. In 1989 they called the same car the Audi 100. So I think you have a 1989 model..if you are here in the States.
Shop around for a Bentley..if you have a 1989 here is a set of books on ebay: https://www.ebay.com/itm/Three-Volum...kAAOSw3uBZrGrG
The clock may need replacement. As I recall the clock was used in other Audi/VW models around the same year. You will need to send the speedo out for repair. The plastic gears break.
TT twister
10-01-2004 10:01 AM
